Front axle seals replacement.
Old Mar 5, 2014 | 12:09 PM
Yogi's Avatar
Default Front axle seals replacement.
I will be attempting to replace a leaking axle seal on the drivers side of my 4 Wheel Drive Suburban. Before I start the process, I would like to know if the the entire front unit has to be removed or if the axle can be taken out while in place on the Suburban. I have been told that the axle can just be popped out like a CV axle on front wheel drive cars. If so, the removal and replacement of the axle shouldn't be a problem. However, I would like to know if there is a C-clip or retainer that keeps it in place after the CV axle is removed from the flange on the short axle. Appreciate any info on the R & R procedure for the axle.
Thanks
Old Mar 5, 2014 | 7:30 PM
what year?
l/f side can be driven out. sometimes it can be hard to hammer out. if this is the case put pressure on one side of the stub shaft flange with a pry bar and hammer the opposite side. this keep even pressure on both sides, hammering alone can wedge one side tight.
the r/f side should not be hammered out. The axle tube should be unbolted and the cir-clip removed with snap ring pliers. if you try to hammer it out you will bend one of the flat washers that sit near the clip.
Old Mar 5, 2014 | 11:52 PM
Yogi's Avatar
Default Axle seal replacement
Thanks for the response on how to remove the left side axle. My Suburban is a 2008 4wd 1500 with a 5.3L V-8. I am considering replacing the seals on both sides. You mentioned there is a clip that has to be removed on the right hand side with snap ring pliers. Is the clip an internal part on/in the front unit?
Old Mar 6, 2014 | 7:28 PM
once you unbolt the right axle tube housing from the front diff...the clip is under a washer. Once the clip is removed the axle shaft can be pulled out of the axle tube and then the seal can be removed.
Old Mar 7, 2014 | 4:02 AM
Yogi's Avatar
Default Leaking axle seals
Thanks for the reply on the clip to be removed. I was able to get an illustration of all the components of the front end and axles. Appreciate the feedback on what needs to be done.
While I am at it, I will also be replacing both CV axles and wheel hubs. Should take up a day if everything goes according to plan.
Nat
Sep 8, 2011 10:57 PM
usmarine0905
Jul 12, 2010 10:16 AM
sledneck421
Jun 14, 2010 8:36 PM
itlldue
Oct 22, 2008 9:05 PM
BCKNBLK
Jun 26, 2006 11:41 AM
