Front Suspension "Pop"
Old Oct 5, 2011 | 2:17 PM
kentxdrifter's Avatar
Cool Front Suspension "Pop"
My 2001 Suburban 2500 has a noise in the front that my mechanic cannot find. After Backing up while turning (i.e. backing into a parking space), There is a pronounced "POP" when the steering is returned to center and the truck moves forward. Ball joints, tie rods, steering box, sway bar bushings, etc. all OK. Replaced upper driver's side ball joint. All others OK. No driveability issues. Just annoying POP. Any ideas?
Old Oct 6, 2011 | 8:43 AM
SabrToothSqrl's Avatar
Default 4x4?
front axles? CV joints?
Old Oct 6, 2011 | 3:45 PM
Yeah Im thinking something with the steering linkage, possibly wheel bearings...
Old Oct 7, 2011 | 7:08 AM
bobehud's Avatar
Wink
have them check your sway bar link kits
Old Oct 7, 2011 | 8:38 AM
Thanks for the reply. It is 2wd. Both wheel bearings are new. Will have sway bar link kits checked. Don't know whether they checked that or not. I do some of my own work so is there a visual or other check I might be able to do?
Old Oct 7, 2011 | 12:22 PM
Something else to consider/check is motor and transmission mounts...try to push up on the trans tail-stock and see if you can see any separation or cracks
damone
May 8, 2021 12:36 PM
Platinum
Jan 16, 2019 9:53 PM
kentxdrifter
Sep 21, 2011 6:16 PM
chevyman323
Jul 16, 2010 11:56 AM
mike688
Uplander
Jan 25, 2010 12:16 PM
