Fuel Guage
Old Jul 15, 2013 | 2:51 PM
warf1955's Avatar
Thumbs down Fuel Guage
The fuel gauge jumps all over the place while going down the road. The only time I seem to ge an accrate reading is if I set still long enough for the fuel to settle down or if I fill the gas tank up. What could cause this problem ?
Thanks
Old Jul 15, 2013 | 8:02 PM
tobaccoman66's Avatar
I had that issue in my 99. I poured marvels mystery oil in the gas over about 5 tanks and now it is steady and accurate. . I think my sending unit was full of crud
Old Jul 16, 2013 | 5:52 AM
warf1955's Avatar
thanks I will give it a try.
Old Nov 30, 2015 | 11:35 PM
warf1955's Avatar
Tried the oil trick it settled down some. Now I get a fairly accurate reading to 1/2 tank. Now it does not have to be moving, When I start the engine it starts going crazy. It goes all the way past full and only stops when it hits th needle on the gauge below it. Some times it goes from full to empty then back to full or where ever it decides to stop then some times it just moves all over the face of the gauge.
Old Nov 30, 2015 | 11:53 PM
What year is your truck? There was a problem with the stepper motors for the gauges from 2003 to 2006. Usually when one of the gauges goes bad, the others will follow. I had that problem and replaced all 6 of the stepper motors.
Old Dec 1, 2015 | 2:27 PM
warf1955's Avatar
1997 Chevy Tahoe (it is the one I use as my avatar. )
Old Dec 2, 2015 | 2:02 AM
Back to the sending unit or a bad wire or connection between the sending unit and the gauge.
strictly chevy
Nov 2, 2009 2:05 PM
k577
Nov 28, 2007 7:21 AM
wen
Oct 18, 2007 1:00 AM
04impala
May 1, 2007 1:55 PM
blazinblazer
Dec 16, 2006 6:44 AM
