Fuel pipe source?
Old Oct 27, 2020 | 9:17 AM
stilllearning6's Avatar
Default Fuel pipe source?
2003 Tahoe 5.3L Flex:
Looking to source the "metal fuel filler pipe" that resides above the beam behind the fuel tank.
GM PN # 15124906.
List dealer $117 , discontinued and pricey.
Can anyone suggest a generic metal fuel filler pipe?
Each end of the metal filler pipe feeds into heavy rubber filler hoses:
one rubber hose comes from the filler neck gas cap,
the other rubber hose leads to the fuel tank.
I guess that GM decided that a rubber hose rubbing over / against the cross beam frame would not be prudent.
It seems that any metal fuel pipe will function correctly.
Old Oct 27, 2020 | 10:47 AM
PNW NBS Z71's Avatar
As badly rusted as both pipes are, you should replace both. Here is the assembly at RA: https://www.rockauto.com/en/moreinfo...839660&jsn=713
You should never just throw some pipe in there for fuel. The OE pipe has has raised edges at the ends for a better hose seal with a clamp.
Old Oct 27, 2020 | 11:18 AM
Thank you.
tbb2
21
Jan 1, 2021 10:01 AM
watersteps
Nov 10, 2019 5:08 AM
stilllearning6
Jul 14, 2019 6:01 AM
RelicAte
Jul 7, 2012 11:15 AM
freddyp
Oct 20, 2009 7:21 AM
