Fuel Pump Wiring on 1999 Suburban
Old May 7, 2014 | 3:44 PM
Mxdad1021's Avatar
Default Fuel Pump Wiring on 1999 Suburban
A squirrel ate the wiring to my fuel pump. It had been replaced once and colors don't all match. I need some help.
The original wire has 2 blacks 2 greys 1 purple/white and 1 green. The new pump connector has a black grey purple/black and an orange/black. The sensor has a black grey and green.
I can't find a wiring diagram to show all these wires.
Please help.
Old May 7, 2014 | 5:15 PM
Terminal Frost's Avatar
no because the replacement sending unit usually comes with a new pigtail... or this is at least my experience with after market units.
see if your local parts store lists a new pigtail for this it might help better unless someone in here can help more
Old May 7, 2014 | 6:10 PM
Mxdad1021's Avatar
I have diagram for the connector. That was easy to find. What I can't find is a diagram to show the existing wires and where the should go.
Old May 7, 2014 | 9:51 PM
this connector... is it an after market part with different wire colors than the other connector ??? can you share pics ???
Old May 8, 2014 | 8:26 AM
Mxdad1021's Avatar
Trial and error finally worked. Got it running. Thanks for trying to help.
Old May 8, 2014 | 4:48 PM
Thumbs up
Good for you. sometimes this is what it takes...
mangomanj
Aug 17, 2014 9:51 PM
BRB
Dec 28, 2012 8:34 PM
hunter10220
May 18, 2011 8:37 PM
juan10
Sep 25, 2009 11:29 PM
treasurehunter01
Jan 11, 2009 11:33 AM
