GForce Chip
Old Jun 15, 2011 | 6:56 PM
Mr.B's Avatar
Default GForce Chip
We have an '09 Tahoe (5.3 liter) and I have been considering installing an aftermarket performance chip, for a little more hp and mileage. Has anyone had any experience with GForce chips? They appear to be bargain basemant priced, but then again.....
Any thoughts or suggestions?
Many thanks.
Old Jun 20, 2011 | 9:45 PM
15 Year Member
Don't waste your money. Check out Blackbear Performance.
Old Jun 21, 2011 | 6:48 PM
LTL4life's Avatar
Go with a Programmer/ tuner . If you need to go to the dealer for warranty related issues, you can reprogram back to stock. this way if they plug into your port and check settings, everything will be stock. what happens if you purchase a tune and the dealer has to reprogram your PCM?
Old Jun 22, 2011 | 12:38 AM
15 Year Member
That's why you buy a separate ECM to put the tune on, then you can reinstall the original for service work.
A good tech can tell if there's been a programmer tune put in and then removed.
Old Jun 26, 2011 | 9:11 PM
big lou's Avatar
+1 With what shark said get a spare ecm cause even if the ecm is set back to factory spec. A snap shot of the ecm will tell the tech that it had a chip.Trans,motor,diff,replacement under warranty most of time gm requires the ecm to have a snap shot done for the claim to be approved to make sure the ecm was not chiped. hope this helps
Old Jun 27, 2011 | 1:36 AM
vrso2's Avatar
may i buy BB, have program it, shipp in EU and just plug in ?? Hmmm, funny part, my brother (in EU) has already installed LPG.
Because the propane gas is half price cheaper than gas, hes gas millage is about half time higher. Thats so cool. He paid 1400 EU for conversion, 110 liters (30 gallon) propane tank is where spare tire was.
Old Jun 27, 2011 | 2:39 PM
15 Year Member
vrso2: Check the Blackbear website. Justin has several options available.
Old Jun 7, 2013 | 4:16 PM
ram49's Avatar
I purchased a Gforce performance chip for my 2008 Silverado. I lost 3 mpg's and can't get it back. They told me to send it back for testing and they would refund if it checked bad. After getting on ripoff.com it sounds like I won't get my money back period. Don't know that for sure yet, but we'll see. They gave me a suggestion on how to reset the ecm. That was to remove the neg. cable from battery, press down on brake pedal 5 to 10 times, wait 30 minutes and reconnect the battery. After about 50 miles it should be back to the original mpg. I'm in the process of doing that now. From what I've experienced I would not buy from Gforce performance chips. I'll keep searching google for another chip that actually works. Thanx, Ray
Last edited by ram49; Jun 7, 2013 at 4:19 PM. Reason: change title to gforce performance chips
Old Jun 7, 2013 | 9:02 PM
15 Year Member
As the saying goes, doing the same thing over again and expecting different results is the definition of insanity.
See post #2.
aaron.63
May 6, 2014 11:22 PM
SOLOLUCKY
Mar 12, 2013 11:43 PM
tux
Jun 11, 2011 1:54 PM
joshf35
Oct 17, 2006 11:26 PM
