have a 2007 suburban sometime it will not start the first turn of the tho?
Old Jun 13, 2019 | 10:39 PM
Maurice Carter's Avatar
Default have a 2007 suburban sometime it will not start the first turn of the tho?
What will cause this problem need help .
Old Jun 14, 2019 | 6:16 AM
harveyspecter's Avatar
For best OBD bluetooth scanners click here
Hi,
When you turn the key, does it crank? If it does, it is not likely that the battery or starter are a problem.
Best thing to do is scan for codes, as this might tell alot.
For instance, you might have a bad crankshaft sensor. This will cause crank-but-no-start situation.
Hope that will help.
Old Jun 14, 2019 | 7:45 AM
You say it will not start the first turn. Does it start after that and just crank for a few extra seconds? If so then you have a bad check valve in the fuel pump assembly.
Old Jun 15, 2019 | 7:39 PM
Default 2007 suburban will start the first try???
Yes it will not start the first try but when I try the second time it start right up?? This always happen, when temperatures are 80 degrees or above??? Love the truck, but this is a sore spot to my ownership.
Old Jun 16, 2019 | 7:27 AM
Do a fuel pressure check at first start up and see what the pressure is.
Old Jun 25, 2019 | 1:52 PM
Default I have-2007-suburban-sometime-will-not start the first turn .
Hey Guys I just put my 2007 suburban in for service for the problem listed above , check back later with the results 😔
