headlight buzzer on 1995 suburban
Old Nov 16, 2024 | 1:12 PM
H2obio's Avatar
Default headlight buzzer on 1995 suburban
My headlight/key buzzer won't shut off so I pulled the relay, but keep forgetting to turn headlights off........
Do you guys think it's a failed relay?
Thanks.
Old Nov 17, 2024 | 8:56 AM
jfmorris's Avatar
It is more likely an issue with the ignition switch. My 1996 does that sometimes, with the key out, and if I stick the key back in and turn a little, I can get it to stop. I sprayed WD40 into the switch and it helped stop it for a while.
Of course, I know my ignition switch is worn out... I can pull the key back out with it in the run position, and the engine keeps going!
Old Nov 17, 2024 | 9:37 AM
Cusser's Avatar
My 1970 VW beetle has been like that since 1978 !!! I got home from work one day and my brother's girlfriend - who he'd just told never to contact him again - was sitting there waiting for him, and I was so pi$$ed I pulled the key right out while the engine was running. So after that I would pull the key out while driving to unlock its glove box to pull out a different cassette tape to play, always surprised passengers !
Old Nov 17, 2024 | 10:05 AM
H2obio's Avatar
Thank you sir, that does make sense. My dad used to shoot graphite in the ignition switch, maybe I'll try that.
Ron
Old Nov 17, 2024 | 10:06 AM
H2obio's Avatar
haha! but why was the console locked???
Old Nov 17, 2024 | 1:08 PM
H2obio's Avatar
tried graphite, it worked temporarily, then tried PB blaster, no love. I guess I'll just live with it.
Thanks all.
Old Nov 18, 2024 | 9:08 AM
Cusser's Avatar
To protect my cassette tapes, and to prevent entry into the trunk....
Old Nov 18, 2024 | 11:01 AM
H2obio's Avatar
Gotcha!
Old Nov 24, 2024 | 9:45 AM
H2obio's Avatar
Following up on this; I ended up tracking down which connector was for the key chime and took a set of dikes to it, problem solved.
Jathen
Apr 7, 2013 12:47 PM
hawkeye1
Nov 2, 2012 9:49 AM
lbcepe
May 11, 2011 5:40 AM
steelerfan7p
Mar 29, 2009 5:15 PM
