Old Aug 10, 2015, 1:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
headlights come on, dash lights go out
Old Sep 29, 2012 | 1:49 PM
hondav4fan's Avatar
Default headlights come on, dash lights go out
on my 2001 tahoe, when the headlights automatically come on when it gets dark ( or you cover up the sensor on the dash ) the daah lights and radio all goes dark - what do I have screwed up and how do I fix it?
Thanks
Bruce
Old Sep 29, 2012 | 4:02 PM
tymr287's Avatar
Thanks
Bruce
Just to be certain, make sure the dimmer switch for your dash lights isn't on the lowest setting first.
Old Sep 30, 2012 | 12:24 AM
hondav4fan's Avatar
no, its not that. when the headlights come on the dash lights just go out instead of dimming.nothing i do with any dimmer or light switches changes it
Old Sep 30, 2012 | 4:42 PM
tymr287 's suggestion is what I thought too... might check all the fuses as well, just to make sure nothing is blown or shorting out...
Re-seating the electrical connector to the lamp switch might be worth a try also...
Old Oct 1, 2012 | 8:25 PM
hondav4fan's Avatar
I didnt mention it before but I checked any fuses and relays under the hood and under the dash that I thought could have anything to do with it. anyone else have any ideas?
Old Oct 24, 2012 | 6:15 AM
jeffmfld's Avatar
I am having the same issue with my 01 Tahoe. The positive batery connection was loose and the truck would not start some times....tightened all connections to the batery and now when the head lights automaticly come on the dash lights go off.
When I use the dimmer to turn the cab lights on the dash lights up but when i turn the cab lights off the dash goes dark again. Help.... I have tried all fuses and connections and nothing.
Old Oct 24, 2012 | 4:55 PM
try disconnecting the battery for a few minutes and see if everything resets?
Old Oct 29, 2012 | 5:16 AM
jeffmfld's Avatar
unhooked the batery for about an hour, no luck.
Old Jan 8, 2013 | 9:35 AM
lovemytahoe70's Avatar
I have the same exact problem with my 2002 Chevy Tahoe....headlights come on, dash lights go out except if I turn on the interior dome light, then the dash lights come on again.
Old Jan 8, 2013 | 9:38 AM
Default Have this same problem!
Thanks
Bruce
Has anyone come up with a solution for this? I have the same problem with my 2002 Chevy Tahoe.
