Heated Seats out - no clicking!
Old Jan 31, 2010 | 7:42 PM
1969bnking's Avatar
Default Heated Seats out - no clicking!
Hey everyone. I have a 2003 Tahoe Z71. My heated seats (both driver and passenger) aren't working right. They both turn on, and after about 30 seconds, turn off. Unlike another recent post, there is no clicking, just a power down.
Then if you turn them back on, they only stay on for about 15 seconds. Each subsquent time, they stay on a shorter and shorter time.
Tried changing the fuse, but still the same result.
Thoughts?? Thanks in advance!
Old Feb 7, 2010 | 12:58 PM
Welcome to the forum. Someone here should have some help.
Old Mar 1, 2010 | 1:19 AM
falcon_406's Avatar
Default Me Too
I have the same problem in my '03 Tahoe LT. Have you found any answers. Thanks
Old Mar 1, 2010 | 9:54 AM
1969bnking's Avatar
Default nothing yet
nope, no solution yet. might switch them on today...see if time solved the problem...I know, wishful thinking.
Old Jan 18, 2011 | 8:43 PM
woodlaker's Avatar
Did you get your problem fixed? Does anyone have any suggestions or advice to this problem? I now have the same problem. Any help is greatly appreciated.
Old Jan 18, 2011 | 8:49 PM
Service Information 2003 Chevrolet Tahoe - 2WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 1864985
#PIT3287D: Heated Seat Inoperative Or Shuts Off In 30 Seconds - keywords B1825 B2435 B2440 B3606 - (Oct 2, 2006)
Subject: Heated Seat Inoperative or Shuts Off In 30 Seconds
Models: 2003-2006 Cadillac Escalade, Escalade ESV, Escalade EXT
2003-2006 Chevrolet Avalanche, Suburban, Tahoe
2003-2007 Silverado Classic
2003-2007 GMC Sierra Classic, Sierra Denali Classic
2003-2006 Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
2003-2007 Hummer H2
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Driver and passenger heated seats inoperative or shut off in 30 seconds. There will be DTCs B2435, B2440, B3606 and/or B1825 set in the Drivers Seat Module. The adjustable pedal position sensor, seat recliner position sensor and both heat seat thermistors share the same 5 volt reference internal to the Drivers Seat Module. A fault in any of these components/circuits can make the heated seats inoperative or shut off in 30 seconds, as well as, the seat recliner and/or adjustment pedals may move in short increments when operated. A fault in heated seats, adjustable pedal or seat recliner will affect BOTH heated seats.
Note:: Even if the vehicle is not equipped with adjustable pedals DTC B3606 still may set.
Recommendation/Instructions:
To help isolate the area of concern use the Tech 2 and go to "Sensor Data" in the Drivers Seat Module. Monitor the following parameters for being out of range:
Recline Position- Normal range .39V-4.58V
Pedal Position (if equipped) - Normal range .39V-4.58V
Psgr. Seat Heat Sensor- Normal range 1V-4V
Drvr. Seat Heat Sensor- Normal range 1V-4V
If a parameter is found to be out of range inspect circuits for any opens, shorts to ground, or voltage. If none found replace the suspect component.
Please be aware of the following common areas of concern:
The adjustable pedal position sensor internally shorted pulling the 5 volt reference low. Disconnect the adjustable pedal position sensor and see if the heated seats start working correctly, if so replace.
Note Important:: The APP (Accelerator Pedal Position) sensor is NOT the adjustable pedal position sensor. Make sure the correct sensor, adjustable pedal position sensor, is disconnected.
The seat recliner position sensor internally shorted pulling the 5 volt reference low. Disconnect the recliner position sensor and see if heated seats start working correctly, if so replace.
An open in either heated seat thermistor circuits (signal or low reference). The most common is the passenger thermistor where it passes through seat connector C305 pin "L" or "K" or C399 pins "R" or "G".
A chaff to ground on either heated seat thermistor signal circuits. The most common is circuit 5475 black/red or dark blue shorted to ground in the passenger seat near the buckle.
Note Important:: The heated seat thermistors act differently to "OPENS and SHORTS" than the adjustable pedal position sensor and seat recliner position sensor. The adjustable pedals and seat recliner sensors can be disconnected for testing of the heated seats. Where as the heated seat thermistor circuit must be working correctly before EITHER heated seat will operate. Disconnecting one thermistor, which may have a concern will not allow the opposite heated seat to work correctly, BOTH side must be operational before EITHER heated seat will operate.
Clearing DTCs
If DTCs will not clear when using the Tech 2 after a repair has been made, try operating the device in which the repair was made. Example, if a repair was made to the passenger heated seat thermistor circuit, the DTCs may not clear unless the passenger heated seat is operated.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a ""do-it-yourselfer"". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2011 General Motors Corporation. All rights reserved.
Attached Thumbnails Heated Seats out - no clicking!-cai32f6p.jpg   Heated Seats out - no clicking!-ca9cql1v.jpg
Old Jan 19, 2011 | 7:12 PM
woodlaker's Avatar
Thanks for the info, however I am somewhat confused with this statement:
Is there two different adjustable pedal position sensor?
Old Jan 23, 2011 | 11:06 AM
kenintally's Avatar
I have a 2004 Suburban Z71 with the same problem. 30 seconds, no heat in either seat. I will follow this post for assistance. Thanks
Old Jan 23, 2011 | 12:17 PM
GeeDubb's Avatar
Default Pedal position vs accelarator position
adjustable pedal position sensor senses the in and out position of both brake and accelerator pedals when setting the pedals for comfort
accelerator pedal position sensor senses the position of the accelerator pedal as your foot moves it to accelerate or decelerate regardless of where your pedals are adjusted for ergonomics
Old Feb 4, 2011 | 1:34 PM
mrstang69's Avatar
I have the same problem with 2009 Suburban. Is this something that can be done by me or do I have to take to dealer?
