HELP-03 Sub Oil Gauge "Weirdness"
Old Oct 1, 2008 | 6:22 PM
mrsmoos's Avatar
Default HELP-03 Sub Oil Gauge "Weirdness"
Bought this Sub in June w/ 42500 miles on it now have 45500 miles. Had oil changed at Walmart about a month or less ago. Today I noticed my oil gauge was OVER 80 while driving in town and way over on the freeway. I called my husband who told me to check the oil. I checked it after it was off and parked for about 30 minutes. It was MAYBE 1/8" ove the criss-cross area by the first dot on the stick. [/align]I started it up and let it run for a few minutes and then checked it. It was almost the same dipstick readingmaybe 1/16" less. The oil looks good and gold honey colored. When I started it up parked, the oil gauge went up to 80 right away and when i gave it a little gas, it went over. You could see it on the gauge when i gave it gas-it would go up and then back down to 80. But today on the freeway it was like 1/2" past 80.[]
It is not acting strange at all other than that. Do I have too much oil in it, a gauge problem or some other kind of problem? I never noticed it running high before!
HELP![/align][/align]
Old Oct 1, 2008 | 7:10 PM
old dog's Avatar
Default RE: HELP-03 Sub Oil Gauge "Weirdness"
a lot depend's on what weight oil they put in at wally world !a little bit over full wont hurt ,just check it on level ground 80 psi is not bad ,but i dont know what oil you had in it before .it's best to get it done at the same place each time so you have a history to fall back on .cheap is not always good !i run 10w30 in my 6.0 2500 4x4 5w30 is kind of light when the miles start adding up .
Old Oct 1, 2008 | 7:30 PM
I would be highly suspicious of the gauge or sending unit. No GM vehicle I've seen ever went over 60 psi, much less 1/2" past 80 psi.
Old Oct 4, 2008 | 10:03 PM
SabrToothSqrl's Avatar
i've had my temp 1/2" past 260 and over the 80 on oil... but I also have 210,000 miles on it... and yet, it still runs!
Old Oct 5, 2008 | 8:42 AM
old dog's Avatar
here again mine has about 43,315 on it and 50 psi at idle 65 at about 1900 rpm .you could have a sending unit problem,or the gauge set needs rebuilt it a problem .
Old Oct 9, 2008 | 12:08 AM
mrsmoos's Avatar
Well Guys, It seems my problem is the Instrument Cluster. After doing a little more "poking around" online, I found a piece about a class-action lawsuit regarding the instrument cluster going bad. My 03 is one of the years mentioned but I have since heard 02-05 models are affected. Usually it is the speedometeryou are going 20 MPH and the speedo says 120! But oil, gas, temp, any of the gauges can go haywireeven the ODOMETER! I am hoping the Sub w/ 42000 miles on it REALLY DID have only 42000 miles on it! Haven't noticed anything with that and did a Carfax before I bought that showed no odometer funny business! It goes in Monday for a whole new instrument clustercourtesy of Chevrolet sinceI had under 70,000 miles on it. I think they said 10 years or 70,000 miles for free repair.
Old Oct 9, 2008 | 10:02 AM
old dog's Avatar
i would be interested to see what sit this is on i am having gas gauge sensor and odometer and shift indicator problems on my 2001 2500hd
Old Oct 9, 2008 | 11:00 AM
mrsmoos's Avatar
http://chevrolet.justanswer.com/chev...ado-instrument
http://z71tahoe-suburban.com/iboard/...16584&st=0
Make sure you read all of that last one.
I am hoping that the "new" one doesn't go bad, too!!!
Old Oct 9, 2008 | 4:28 PM
old dog's Avatar
looks like the help is on the 03 up to05 ,maybe some time later they will loosen up a little bit .
Steelman512
Jun 8, 2023 2:51 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
pj2k3
Aug 24, 2013 5:20 PM
pawzntails
Nov 5, 2008 1:08 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
