Help with code P1820
Old November 11th, 2010 | 7:59 PM
kylemason's Avatar
Question Help with code P1820
I understand that the code diagnoses this...
P1820 Internal Mode Switch Circuit A Low
I think this circut is in the transmission and I need to know if this is correct and how to test it.
1997 Tahoe 5.7l, 4L60, 4 wheel drive, stock everything.
Thanks, Kyle
Old November 11th, 2010 | 8:59 PM
Welcome to the forum...
boy that is a tough code to find
I found this on another forum...
http://www.s10forum.com/forum/f105/w...1870-p-301660/
Old November 12th, 2010 | 7:10 AM
kylemason's Avatar
I read that one last night while googling the code. I am wondering if the code could be because the owner had low transmission fluid level. Hopefully someone can at least tell me what circuit A is, is it a fluid circuit or an electrical circuit.
Kyle
Old November 12th, 2010 | 8:31 AM
The only code I can find in my repair manual is a P1825 which sounds similar to the 1820
attached PDF
File Type: pdf
Old November 13th, 2010 | 5:55 AM
kylemason's Avatar
Looks like your manual is for 2007 Chevys. This is a 1997 with a 4L60 transmission. I don't know which tranny you have but I cant imagine they are the same, so the codes may be different. I see what you mean about the similarity between the description of the codes. I am not sure they are related though. Thanks.....
Kyle
Old November 13th, 2010 | 10:42 AM
I have the 4L60E but its more electronically controlled then the 97, however the document might help give you some general direction as the codes for the most part do not change...
Old November 13th, 2010 | 6:21 PM
kylemason's Avatar
I drove the truck again today and have not had the CEL return. I will recheck the codes on Monday to see if it has returned without lighting the CEL. Thanks for the help.
Kyle
Donthaveone
August 27th, 2013 9:45 PM
Vinna
November 12th, 2012 8:51 AM
ruffrider285
September 5th, 2012 12:08 AM
fred223
November 20th, 2010 9:56 AM
lightGear
Corvette
February 9th, 2007 1:30 AM
Quick Reply: Help with code P1820
