Help with code P1820
Old Nov 11, 2010 | 7:59 PM
kylemason's Avatar
Question Help with code P1820
I understand that the code diagnoses this...
P1820 Internal Mode Switch Circuit A Low
I think this circut is in the transmission and I need to know if this is correct and how to test it.
1997 Tahoe 5.7l, 4L60, 4 wheel drive, stock everything.
Thanks, Kyle
Old Nov 11, 2010 | 8:59 PM
Welcome to the forum...
boy that is a tough code to find
I found this on another forum...
http://www.s10forum.com/forum/f105/w...1870-p-301660/
Old Nov 12, 2010 | 7:10 AM
kylemason's Avatar
I read that one last night while googling the code. I am wondering if the code could be because the owner had low transmission fluid level. Hopefully someone can at least tell me what circuit A is, is it a fluid circuit or an electrical circuit.
Kyle
Old Nov 12, 2010 | 8:31 AM
The only code I can find in my repair manual is a P1825 which sounds similar to the 1820
attached PDF
File Type: pdf
Old Nov 13, 2010 | 5:55 AM
kylemason's Avatar
Looks like your manual is for 2007 Chevys. This is a 1997 with a 4L60 transmission. I don't know which tranny you have but I cant imagine they are the same, so the codes may be different. I see what you mean about the similarity between the description of the codes. I am not sure they are related though. Thanks.....
Kyle
Old Nov 13, 2010 | 10:42 AM
I have the 4L60E but its more electronically controlled then the 97, however the document might help give you some general direction as the codes for the most part do not change...
Old Nov 13, 2010 | 6:21 PM
kylemason's Avatar
I drove the truck again today and have not had the CEL return. I will recheck the codes on Monday to see if it has returned without lighting the CEL. Thanks for the help.
Kyle
Donthaveone
Aug 27, 2013 9:45 PM
Vinna
Nov 12, 2012 8:51 AM
ruffrider285
Sep 5, 2012 12:08 AM
fred223
Nov 20, 2010 9:56 AM
lightGear
Corvette
Feb 9, 2007 1:30 AM
