Help: Suburban non-functioning fuel gauge and P2066 OBD error
Old Sep 13, 2015 | 7:14 AM
ctbimmer's Avatar
Default Help: Suburban non-functioning fuel gauge and P2066 OBD error
I very recently (2 days ago) purchased a 2008 2500 model with 69K miles. Fuel tank was full and gauge/miles to empty all appeared normal on 300+ mile drive home.
Next day when I started it, gauge was basically at completely empty. I put in 10 gallons, restarted truck, and showed about 1/3 tank on the gauge. 10 minutes later, stop/restart truck, and gauge back to zero, where it has remained since.
Later in day, check engine came on, and scanner shows 4 instances of same code, P2066 which maps to Fuel Level Sensor B.
I assume these two issues are related, but I haven't found anything online that points to what the problem is. Do I have a failed fuel level sensor in the tank, or do I have a wiring problem?
Anyone out there with experience with this I'd appreciate some insights.
Old Sep 17, 2015 | 12:19 PM
Official GM Rep
Hello ctbimmer,
We certainly don’t want your newly purchased Suburban to remain in this condition. Unfortunately, because we are not certified mechanics, we cannot provide you any technical insight, however, are happy to assist you in the best way possible moving forward. Have you brought this concern to the attention of a certified dealer? If not, we would be more than happy to contact one on your behalf for a diagnosis. Please send us a private message with your VIN, mileage, contact information and preferred dealer if you have one.
Best wishes,
Helen
Chevrolet Customer Care
Old Mar 8, 2020 | 6:04 PM
Kevin William's Avatar
hello, I’m having very similar issue. Also my truck is dying on me while driving. Replaced the fuel pump and a few other small things but out of no where the fuel gauge shows empty. Did you make any progress with your situation?
hockeyfan
Sep 22, 2018 11:36 AM
Sonicd
May 29, 2014 2:55 AM
Ndog
Cobalt
Mar 21, 2014 2:50 PM
stantonbox
Jan 2, 2008 11:42 PM
stantonbox
Dec 27, 2007 1:14 AM
