HID for Tahoe?
Old Mar 2, 2010 | 6:04 PM
enacer's Avatar
Default HID for Tahoe?
Im picking up my 2010 Tahoe LTZ on friday. I noticed there wasnt any HID option, has anyone modified the stock headlights to HID or PIAA bulbs?
Old Mar 3, 2010 | 9:21 PM
Most of the aftermarket suppliers offer HID kits. Remember 4300K is white. The higher the color temp, it goes from blue to purple and the lite output decreases and the ability to get stopped increases.
Old Mar 4, 2010 | 9:08 PM
yukon07artic's Avatar
go for the ddmtuning hid lights
Old Mar 14, 2010 | 8:49 PM
enacer's Avatar
bump...anyone else? anyone try tophidkits.com?
Old Apr 28, 2010 | 12:50 PM
SilveradoerZ's Avatar
Originally Posted by enacer
Im picking up my 2010 Tahoe LTZ on friday. I noticed there wasnt any hid option, has anyone modified the stock headlights to hid kits or PIAA bulbs?
You can with the 8,000K. A great set and not tacky like most drivers like it.
Old Apr 28, 2010 | 12:59 PM
ChevyguyArmen's Avatar
I bought an inexpensive HID kit on ebay. It has the 2 ballast and the 2 low beam H11 bulbs. I went with the 4300K which is like a high white color. I had the 5000K in my silverado and they looked good also. I did not change the high beam or fog lights to HID.
Old Apr 29, 2010 | 6:28 PM
You must like purple.
Remember that the stock housings aren't designed for HIDs. You need a projector housing to really get the desired effect and not just blind oncoming drivers.
Old Apr 30, 2010 | 8:57 AM
enacer's Avatar
Originally Posted by 73shark
you must like purple.
Not just blind oncoming drivers.
:d:d:d:d:d:d
Old Apr 30, 2010 | 9:48 AM
ousig2408's Avatar
you won't blind anyone unless the bulb is exposed and/or is not coated on the end. some housings have the full bulb exposed and if you put regular HID bulbs in there they WILL glare and blind other drivers unless you get the bulbs that have a coated tip. our truck has the little cover over the bulb and that is enough to keep glare down
Old Apr 30, 2010 | 4:42 PM
I still say that w/o a projector lens, the HID will produce glare, maybe not as much w/ coated tip but still not as directed.
MattWeed
Apr 30, 2008 11:17 AM
SWRidin
Dec 7, 2007 5:51 PM
n77nxc
Nov 5, 2007 10:50 PM
VKtahoe
Nov 29, 2006 3:34 AM
cecook
Aug 8, 2006 2:19 AM
