HIDS for 07 Tahoe?
Old Jan 22, 2007 | 2:55 PM
07HoeDown's Avatar
Default HIDS for 07 Tahoe?
Anyone on here installed some HIDS. So it would like like the Escalade lights? If so what bulbs did you use, and whats the intensity (6000K or 8000K, etc...)
Old Jan 22, 2007 | 3:16 PM
xclusive's Avatar
Default RE: HIDS for 07 Tahoe?
you can do a search for HIDs in this section and find some more info.
the bulb sizes are H11 and i did 6000k cause i didnt want to deviate from the pure that much.
the only issue i have with them is that when its cold outside only one light turns on and sometimes neither come on unless i keep turning the headlightswitch on and off.
Old Jan 22, 2007 | 3:29 PM
07HoeDown's Avatar
Thanks.. Do you think your issue with the bulbs not coming on are related to the kit that you purchased or is it related to truck? Do you have any pics of them on?
Old Jan 22, 2007 | 5:48 PM
DarkOne's Avatar
go to the website www.xtralights.com they some HID conversion kits.
Old Jan 22, 2007 | 8:22 PM
xclusive's Avatar
i thnk it has to do with the truck and the auto yurn on headlights. no i do nothowever i will try to get u a pic. u can also visit xenonking.com thats where i purchased them from. they were a lil expensive but i thats because i got the phillips HID kit.
ORIGINAL: 07HoeDown
Old Jan 22, 2007 | 11:20 PM
LTZ_HOE's Avatar
I have installed the 6k on mine. I purchased from xenondepot.com. I have had no problems with them. The only problem I have had is that one light will turn on. I think this is due to the fact that it was cold outside. I love the way the lights look. I get much complaments on them.
Old Jan 23, 2007 | 2:22 AM
xclusive's Avatar
i get the same problems with mine when its cold out. its a pain in the @ss to get the other one to come afterone is already on.
ORIGINAL: LTZ_HOE
Old Jan 23, 2007 | 3:02 AM
engine2's Avatar
ORIGINAL: DarkOne
cool link with HID demo in a fish tank full of water
Old Jan 23, 2007 | 12:40 PM
vyslouzil's Avatar
you need to install the lights using a relay and a direct connection the to the battery. the initial amp draw is too high for the stock harnesses to keep up with. most kits come with the wiring setup for a relay.
now if you are already using a relay system, then the problem with your cold starting is one of your ballasts is going out.
ORIGINAL: xclusive
Old Jan 23, 2007 | 2:04 PM
xclusive's Avatar
do u have a wiring diagram of how it should be?
ORIGINAL: vyslouzil
