Is a high oil pressure reading more likely to be the sending unit or stepper motor?
Old Nov 5, 2021 | 10:33 PM
Sintek's Avatar
Default Is a high oil pressure reading more likely to be the sending unit or stepper motor?
'02 Tahoe
At idle the gauge shows 60psi, and with any amount of acceleration it hits 80. Obviously the readings are inaccurate and I want to fix it in case I ever need to know the real oil pressure. I thought I'd ask before throwing an unnecessary part at it if the sending unit or gauge or something else is most likely responsible.
Thanks for any help.
Old Nov 6, 2021 | 7:24 AM
repairman54's Avatar
Sensors are the most common thing to fail. Use a GM part and not aftermarket stuff as aftermarket sensors are not reliable.
Old Nov 6, 2021 | 8:53 AM
hanky's Avatar
Suggest you consider getting a reliable pressure gauge and connect it in place of the sending unit.
At least you will know what the actual readings are and go from there.
Old Nov 6, 2021 | 9:59 AM
kevinkpk's Avatar
Originally Posted by Sintek
'02 Tahoe
Transducer is more than likely at fault. I had the exact thing last year.
Ronin1014
Jul 1, 2014 8:47 AM
ice-fishin
May 24, 2013 10:36 AM
gunsbillygun
Jun 13, 2010 7:40 PM
mac55
May 7, 2009 8:57 PM
Kabraxiz
Oct 2, 2007 12:49 AM
