how to change diff. oil on 08 Suburban?
Old Feb 21, 2010 | 8:07 AM
lawman34203's Avatar
Default how to change diff. oil on 08 Suburban?
Can anyone tell me or point me in the right dirrection as to how I can change the diff. oil on my 08 Suburban. Also, would you recommend I use something like Royal Purple if I do some towing?
Old Feb 21, 2010 | 10:44 AM
s34n's Avatar
if your changing the rear diff oil. its simple nothing complicated.
unbolt the diff cover
let oil drain out. get a can of "the right stuff" its a silicone gasket maker in like a squeeze cheese can type.
put that on your diff cover
replace the diff cap to the diff
bolt it back on tighten the bolts with a ratchet hand tight then an 1/8th turn more.
wipe all the excess right stuff off.
there should be a bolt on the right side behind the diff by the driveshaft and should take a 3/8 drive to take it out. fill it til fluid starts coming out.put the bolt back on. drive it for a few days check it and refill if needed.
im using royal purple and havent had any problems with it. i would recommend it. any questions just ask
Old Feb 21, 2010 | 10:55 AM
seanw's Avatar
Be careful not to use too much silicone...
Old Feb 21, 2010 | 11:35 AM
Thanks guys, easier than what I thought it would be.
Old Feb 22, 2010 | 8:00 PM
8rings's Avatar
FYI, Haynes makes a manual that details these maintenance procedures. It is for the Silverado but also covers the SUVs. You can pick one up for $15.
Old Feb 23, 2010 | 8:56 AM
ousig2408's Avatar
I am new to these trucks, at what mileage should this be replaced and are their any benefits to using anything other than GM fluid? we just got a 2007 Tahoe that has 46k miles. It looks to have never been used for towing and we probably wont tow much of anything either. Just a gas hog family hauler!
thanks
Old Feb 23, 2010 | 3:48 PM
Your owner's manual details maintenance intervals.
Old Feb 24, 2010 | 6:43 PM
s34n's Avatar
chiltons imo is better then haynes.
Old Mar 27, 2010 | 4:48 PM
atis's Avatar
I second that... I have the Haynes for the Tahoe and a Chilton for the Stang...Chilton has more detail and is more specific to the vehicle.
SabrToothSqrl
Jun 23, 2015 10:44 AM
therewolf
11
Aug 11, 2008 12:34 AM
hamcginn
Colorado
Feb 5, 2008 4:57 PM
Faith_plus_1
Mar 2, 2007 3:17 PM
digdug
Feb 4, 2007 3:08 PM
