How do remove my speedo?
Old May 12, 2007 | 9:23 PM
07hoeon26's Avatar
Default How do remove my speedo?
I want to send it out to get some custom overlay installed I just don't know how to take it out maybe someone can help?
Old May 12, 2007 | 9:24 PM
07hoeon26's Avatar
Default RE: How do remove my speedo?
It's an 07 LTZ
Old May 13, 2007 | 10:27 AM
jazejeff's Avatar
well first you have to remove your driver side a/c vent by pulling up on those 2 tabs inside the vent .
then you will find a screw behind there that will release half of the surrounding plate that you need to get off ..
then you need to the same thing on your passenger air vents(the ones next to your wheel)once you do that there is another screw that you need to take out to release the other half of the surrounding plate
once youhave that piece out the you will see the screws around the speedo that need to be removed
Old May 13, 2007 | 8:27 PM
CTAvy's Avatar
I was looking at my Avalanche this morning (also an '07 LTZ) and got as far as pulling the two screws from the underside of the top of the arched trim around the cluster. And from there I quickly figured out that the A/C vents had to come out, but I don't see the tabs you mention needing to pull on. I see *one* thing on the driver's side at the bottom center of the vent, but nothing similar in the center vents. I pulled and pried (gently) here and there, but nothing seemed to come loose. Can you elaborate more on what I need to be looking for? Thanks!
Old May 13, 2007 | 9:20 PM
jazejeff's Avatar
inside the vent on the top and bottom there is a small tab that has to be lifted up so you can realese the a/c vent
i will take some pics tomorrow before work
Old May 20, 2007 | 9:18 PM
07hoeon26's Avatar
Thank you jazejeff.
mmonkey81
Aug 6, 2009 1:30 PM
flyinYFZ
Apr 17, 2007 12:25 PM
bostonkillers
Feb 12, 2007 12:41 AM
b1pig
Nov 21, 2006 2:35 AM
