How to get up between rear 1/4 panel sheet metal?
Old Jul 11, 2009 | 1:26 PM
Hardin Thicke's Avatar
Default How to get up between rear 1/4 panel sheet metal?
Body guys, I need your help! How do I get up between the rear quarter panel sheet metal? I've investigated everything; removal of the wheel liner, tail light, jack storage area. I can't find access to it. Here's the story, I need to bolt an antenna mount which I use for my amateur radio operations to the rear quarter panel's outer sheet metal. There's a backer plate to stiffen the sheet metal around the mount, andt to bolt it in place, I need to be able to get behind the outer skin. Any ideas? I have a lot invested it this project, and didn't expect I couldn't do what I want to do.
Old Jul 11, 2009 | 4:16 PM
old dog's Avatar
Default mount
if you cant gain access from the tail light area ,or the fuel filler area you might have to cut a round access hole from the jack area and screw or rivet a cover plate over the hole.
Old Jul 11, 2009 | 4:40 PM
Might check w/ a dealer's body shop and see if they can shed any light.
SILVERAD01
Aug 26, 2015 4:24 PM
fishbreath
Jun 6, 2014 10:33 PM
thomis
Mar 27, 2014 6:39 AM
haledavis
Feb 18, 2014 11:38 AM
southern slammer
Sep 21, 2007 6:49 PM
