Will a climate control unit "plug&play" into an 01?
Old Jul 9, 2009 | 7:48 AM
94burbin's Avatar
Default Will a climate control unit "plug&play" into an 01?
I have an 01 suburban that has the 1 & 2 speed on the the blower switch is non operational. I was thinking of swapping out that whole unit and dropping in a newer climate control version found on the newer models. Anyone know if it's a "plug and play" deal? Or is it easier just to replace the blower switch which I assume is the issue.
Old Jul 9, 2009 | 11:42 AM
SabrToothSqrl's Avatar
Default Hvac
the ones that can adjust the temp ie you set 72 and leave it... require mucho sensors in the vehicle... outside, inside, i think my 09 even has a 'skin temperature' sensor
your better off googling the part # and trying to find one to replace it...
sorry...
but! I may be wrong... g'luck
Old Jul 9, 2009 | 11:50 AM
94burbin's Avatar
I was thinking of the newer years up to 06. 2007-09 are a whole new beast.
Old Jul 11, 2009 | 6:40 PM
shawnvw's Avatar
Banned
your problem is probably the blower motor resistor, not the switch....have you diagnosed it to the switch?
kenndavis357
May 5, 2014 5:02 PM
hidextra.com
Oct 18, 2010 3:03 PM
msmrx57
Sep 16, 2010 8:21 PM
punkieys17
Oct 17, 2007 6:11 PM
tumark
Aug 20, 2007 1:23 PM
