How hard is it to r&r oil pan?
Old Mar 7, 2014 | 6:50 PM
alsohim's Avatar
Default How hard is it to r&r oil pan?
2003 Chevy Suburban LS 4X2 5.3 216,000 miles
Had instrament cluster rebuilt, oil pressure went to 80 psi constant. Replaced sending unit now 40 at idle 58 on highway.
Here is the bad part!!!
After 20 miles or so oil pressure gauge starts going from 58 down to 50 psi and right back. I think the issue is a bad pump or a bad O ring on oil pu tube.
How hard is it to drop pan and chk oring?
Thanks in advance
Kaleb
Old Mar 7, 2014 | 8:45 PM
you have to remove the front diff. if you can do that, the rest is a piece of cake.
Old Mar 8, 2014 | 6:45 AM
alsohim's Avatar
Well since it is two wheel drive (4X2) will that make it easier?
thanks
Kaleb
Old Mar 8, 2014 | 7:43 AM
yep, you will have lots of room to drop the pan
Old Mar 9, 2014 | 6:17 AM
alsohim's Avatar
Thanks when warms up on jack stands Fix pan leak and replace O
Ring. Tks
Kaleb
Old Mar 9, 2014 | 6:50 PM
magician's Avatar
My Tahoe is an 08 twd and when I did mine I had to lower the steering rack to fully remove the pan. The pan will come down some but not enough to get it completely down and give you access to the pick up O ring.
Old Mar 10, 2014 | 4:06 PM
alsohim's Avatar
thanks,
Kaleb
Casual Mechanic
Jun 22, 2015 11:20 AM
jondoe28
May 30, 2007 7:59 PM
SANTOS29
Mar 19, 2007 1:58 PM
91z28camaro32
Mar 2, 2006 8:11 PM
paulk
Feb 11, 2006 2:20 AM
