How to hookup power to a transmission temp gauge?
Old Aug 12, 2010 | 7:43 AM
santurinos's Avatar
Default How to hookup power to a transmission temp gauge?
I need to install a temp gauge for my tranny. Probably right under the dashboard. I need the + wire from the ignition and the power line for the lights (for dimming the gauge).<o></o>
Is there a convenient place like a plug or wires under the dashboard?<o></o>
Thank you fore your help and have a nice day, walter<o></o>
Old Aug 12, 2010 | 8:11 AM
Welcome to the forum Walter
What year of vehicle do you have as each hook up can be different....
Old Aug 12, 2010 | 9:44 AM
santurinos's Avatar
Sorry about this...
<link rel="File-List" href="file:///C:/DOCUME%7E1/WALTER%7E3.APP/LOCALS%7E1/Temp/msoclip1/01/clip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <woNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> We finally got our Chevy Tahoe LT – 5.3lt 2006 model with low mileage. We need to tow our trailer (Trail-lite crossover 189QB – 3500lb loaded).<o></o>
This is my first full size SUV - I love to ride this thing. Our first trip in the Georgia mountains was very exciting, my Tahoe did great.
I already bought a new transmission cooler and while trying to install it I just figured out - it has one already installed...
Next time, I read the forums first before ordering...
Still I want to install my temp gauge, just to be on the safe side…
<link rel="File-List" href="file:///C:/DOCUME%7E1/WALTER%7E3.APP/LOCALS%7E1/Temp/msoclip1/01/clip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <woNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> Thank you for your time and support – have a nice day – walter and dianne.<o></o>
<o></o>
Last edited by santurinos; Aug 12, 2010 at 9:49 AM. Reason: transmission cooler already installed...
Old Aug 12, 2010 | 10:52 AM
Give this link a try... put in your vehicles VIN number and you can find out what options your vehicle has including the transmission cooler what type of rear end it has and other options that can come in handy...
http://www.compnine.com/vid.php?vin=Enter+VIN
I know on my 07 Tahoe I have the DIC or driver information center button that displays my transmission temp, I am not familiar with the 06 or if it has the same display available... someone with and 06 model may be able to give more info so stay patient...
Old Aug 12, 2010 | 4:12 PM
santurinos's Avatar
Default tranny temperature sender installed and prewired ?
Is it possible to buy a aftermarket gauge and install it on the cluster? Is the tranny temperature sender installed and prewired regardless if whether or not the vehicle originally came with the tranny temp gauge or not?
<link rel="File-List" href="file:///C:/DOCUME%7E1/WALTER%7E3.APP/LOCALS%7E1/Temp/msoclip1/03/clip_filelist.xml"><!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <woNotOptimizeForBrowser/> </w:WordDocument> </xml><![endif]--><style> <!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style> Thank you for your support – have a nice day – walter and dianne.<o></o><o></o>
Old Aug 12, 2010 | 5:40 PM
My daughter had a '03 Denali that had a tranny temp gauge in the lower left corner of the cluster. Not sure why unless it was part of a trailer pkg. She doesn't have anymore.
You might check w/ a knowledgeable Chevy dealer's service dept. and see if a factory gauge would work for you.
Of course you can always use a fuse tap to get ur 12V.
Old Sep 4, 2010 | 9:20 PM
buzz9933's Avatar
Default trans temp guage
99-06 1/2 tons (1500)didn,t have trans temp & it wasn,t available as an option.3/4 tons,denali ahd trans temp guage.for my 04 1500 suburban I just replaced entire instrument cluster(actually used one from an escalade)as my tach & voltmeter quit(common problem-too many miles & generous motors said no to warranty request).it is just plug-n-play,nothing to wire in.
Old Sep 10, 2010 | 7:12 PM
blaze_32001's Avatar
yea i have the SS cluster on my '04 silverado. and i did the DIC on it too since it didnt come with that option which ment i had to change the steering wheel. very happy now though.
Old Dec 30, 2010 | 6:26 AM
Quinny757's Avatar
Hello Im looking to do the same thing as upgrade mt cluster to an Escalade. I have a 00 Suburban 1500. I understand that I can only use a 2002 escalade cluster correct? I cant seem to find any!
gstuck1956
Jul 25, 2015 1:06 AM
tman94
Apr 15, 2014 7:58 PM
chevy619
Oct 7, 2012 10:40 PM
Mauler
Mar 2, 2009 6:40 PM
wrxsubaruwrx
Dec 3, 2006 12:33 PM
