How to Relieve Fuel Pressure
Old Sep 11, 2009 | 7:29 AM
knapp9's Avatar
Default How to Relieve Fuel Pressure
I have an '03 Suburban. Does anyone know the correct procedure for relieving the fuel pressure? I am going to replace the fuel filter, but want the pressure released 1st. Thanks
Old Sep 11, 2009 | 7:40 AM
MDTAHOE's Avatar
Professional Mechanic
You can push the shradder valve on the fuel rail which will only relieve the pressure but fuel will still run all over the place. You can start the truck and pull the fuel pump fuse which will run the line almost empty. In the shop we just remove the filter without doing anything first but we do not care if gas gets on the floor.
Old Sep 13, 2009 | 7:57 PM
knapp9's Avatar
I've pulled the fuse on my Ford Escape and that approach seems to work okay.
Is this the fuel sensor in the photo (above and to the right) of the filter? Won't I accomplish the same if I disconnect that senosr? Thanks.
Old Sep 13, 2009 | 8:51 PM
MDTAHOE's Avatar
I can not really tell what that is in the photo but there is no sensor that you can unplug to accomplish what you want to do.
bholaday
Apr 2, 2021 5:51 PM
solerano
Sep 1, 2013 5:26 PM
Aaron@Airlift
Aug 2, 2012 9:33 AM
gdavies07
Nov 7, 2011 11:47 PM
williamvaldivia
Mar 19, 2009 11:03 PM
