HVAC Frack'd
Old Aug 14, 2014 | 7:17 AM
SabrToothSqrl's Avatar
Default HVAC Frack'd
Hopefully someone gets the BSG Reference.
So when I maxed out the fan speed on my auto HVAC in my 09 Tahoe LTZ, it sounds as if the fan is speeding up, slowing down, speeding up, slowing down, speeding up, slowing down..
turns out... it's the 'mix' setting. Whatever device actually physically moves to send air to the dash or your feet is causing this.
when I put it on dash, everything seems fine. When I put it to mid, it does it, when I put it to feet, I still get airflow out of the dash vents....
UGH! GM quality in action...
I have the FSM at home, but didn't know if you guys knew what parts may have failed?
It seems to have a hard time adjusting between dash and feet... it's slow to react and won't physically hold the position...
where do I look? Do I have to rip out the whole dash?
Old Aug 14, 2014 | 9:29 AM
(raising my hand to the BSG reference )
You might try the relearn procedure as a place to start...
pull the HVAC fuse for 10 seconds, start the vehicle and let HVAC do its relearn for 1 full minute (really 40 seconds) don't make any adjustments during that time..
Old Aug 14, 2014 | 10:32 AM
Default HVAC Learn
The HVAC has a learn procedure?!
So pull the fuse, engine on. wait 1 min, then put fuse in?
is this fuse powered while the truck is off?
If not, then isn't turning the vehicle off the same thing?
Should I just pull the battery for 10 min and let the truck sit?
I did notice a weird behavior, that I don't know if it's normal.
with the HVAC OFF, i pushed the temp down button, it lit up, changed the temp, then screen went blank again.
tried again, same thing. (is this normal)?
when I push the fan adjust or the on or auto button, it turns on fine.
Old Aug 14, 2014 | 10:52 AM
  1. Engine off, Pull HVAC fuse, wait 10 seconds re install HVAC fuse (under hood fuse box)
  2. Start engine, HVAC system will be on and the system will be in a relearn mode, Do Not make any adjustments to system for a full 1 minute while doors calibrate.( you can hear the doors moving)
  3. After full 1 minute calibration should be complete and system operation can be verified...
Old Aug 14, 2014 | 11:08 AM
Default hmm
thanks!
is this out of the FSM?
Seems simple enough, after I replace a boat raw water pump tonight I'll give it a shot.
Old Aug 14, 2014 | 11:16 AM
Originally Posted by SabrToothSqrl
thanks!
Yup from the FSM here is the full text
https://chevroletforum.com/forum/tah...bration-55521/
Old Aug 14, 2014 | 12:50 PM
Default nice
printed it out!
you the man!
what is a DTC?
According to the Manual it's fuse 39 under the hood.
"39 Climate Controls (Battery)"
Old Aug 14, 2014 | 1:00 PM
Default parts
if the re-learn doesn't work...
is this what I'd most likely need?
2003-2010 Chevrolet Tahoe HVAC Floor Mode Door Actuator - Climate Control - Standard Motor Products 03-10 Tahoe HVAC Floor Mode Door Actuator - 3734-05209114 - PartsGeek
Old Aug 15, 2014 | 7:21 AM
Default Good News! No wait, the other thing.
Now it's stuck on defrost, even when I say I want vent / floor... FML. I have a 200 mile drive coming up and will need my A/C.
I reset it again, and am going to leave it until I can take it somewhere... I'm way to busy to even think about fixing this right now..
bigredpro
Nov 23, 2007 7:56 PM
The01Cav
Aug 31, 2007 6:41 PM
Rescue30
Jun 29, 2007 12:59 PM
dupont
Apr 2, 2007 9:52 PM
ZX1100F1
Feb 28, 2007 9:06 PM
