I need info on torsion bars
Old May 28, 2009 | 7:36 PM
robertmack83's Avatar
Default I need info on torsion bars
Can anyone tell me how torsion keys work. And what are the pros and cons of turning torsion bars to level out my suburban.
Old May 28, 2009 | 9:22 PM
old dog's Avatar
Default bars
tightening them up raises the front end but makes it stiffer ,increases the front spring rate .the new keys change were the adjustment start's and stops ,allowing more lift .but either way you will need a alignment .
Old May 28, 2009 | 9:27 PM
EvansBlue's Avatar
It will ride very bad. I could understand if you were doing it with a Silverado, but in a Suburban, you typically haul people a lot more often. People don't like their heads slamming into the headliner.
Old May 28, 2009 | 9:38 PM
old dog's Avatar
Default bars
i have had mine done since 03 it does not ride that bad it leveled it and it Carry's the plow better ,the suburban is a little bit heaver than than a pickup ,might not notice it that much .if there is very much adjustment left on the bolts you can usually get about 1 3/4 max ,try the adjustment first before you go for the key's .
Old May 29, 2009 | 4:53 AM
thanks for the help and information
davbell22602
1988 - 1998 (GMT400)
Jan 9, 2010 5:46 PM
BlkSilv01
Jul 6, 2009 8:21 AM
jmckeage
Feb 19, 2009 10:39 AM
baddog15
Dec 8, 2008 2:52 PM
ussva
Jun 3, 2008 12:07 AM
