If you have no idea what kind of Mobil 1 synthetic was used...
Old Nov 15, 2007 | 1:52 AM
guvner's Avatar
Default If you have no idea what kind of Mobil 1 synthetic was used...
And you just got the care used what would be a safe choice for a spare kept with the vehicle?(I was toldthe owner had used Mobil 1 synthetic. I didn't ask or know how many there were.) I just bought some 10w 30 extended Mobil 1 synthetic. The vehicle is saying an oil change is a long way off. Any recommendations? One of the Mobil 1's said Ford and Chrysler while this one had a GM rating so I got it. Was the most expensive one of the bunch so I was hoping it was the right choice.
While I'm there what would you guys recommend for a 33,000 mile vehicle on my next oil change?
Thanks,
Gary
Old Nov 15, 2007 | 7:52 AM
Dave Tyler's Avatar
Default RE: If you have no idea what kind of Mobil 1 synthetic was used...
You will get alot of opinons here, here is my 2 cents. I would change the oil now, you know when it was done then, and on Mobil 1 I would go an easy 5000 miles but no more, no mater what you read. You will be good. Don't forget the other fluids, rear end, auto trans, and if 4 wd your transfer case, and front diff. When you get it all done you will know it has been done and maybe check the antifreeze too? If you are in a real cold area the 5w30 would be O.K. too. Good Luck!![8D]
Old Nov 15, 2007 | 9:22 AM
ZX1100F1's Avatar
Agree with Dave (above) for the most part except Mobil-1 will go much longer then 5,000 miles without any problem even though most people are understandably hesitant to do so.
If I were to purchase a used vehicle I would go through it and replace all the fluids and filters if it had over 30k miles using all synthetic lubricants.
5W-30 is recommended and the prefered oil for your Tahoe year round, if using Mobil-1 reset the oil life monitor at the time of the oil change and go by it.
Be sure to not use a solvent engine cleaner or motor flush in the crancase ever (not that you would).
wep54
Nov 11, 2013 8:49 AM
Danistheman1234
25
Aug 9, 2011 5:16 PM
Danistheman1234
May 26, 2011 6:59 PM
mike3401
Camaro
14
Sep 22, 2009 11:47 AM
