ignition key cylinder removal 98 tahoe
Old Oct 3, 2007 | 5:26 PM
dirtywhiteboy's Avatar
Default ignition key cylinder removal 98 tahoe
i wanna know if im gonna have problems with the airbag deployingin the steering wheel if removed. I've heard the wheel doesn't need to be removedbut i cant see how it doesn't. can someone enlighten me???
Old Oct 3, 2007 | 5:58 PM
ZX1100F1's Avatar
Default RE: ignition key cylinder removal 98 tahoe
Disconnect the possitive (+) cable from the battery and touch it to the negative (-) terminal and then leave disconnected while you are performing any work on the Tahoe to prevent airbag deployment.
The above procedure will completely drain the system of residual voltage.
Yogi
Dec 15, 2015 5:11 PM
frosome
Dec 12, 2014 7:15 PM
Chevyaz
May 20, 2013 6:51 PM
KeyserSozae
Nov 28, 2011 6:03 PM
1968ss
Mar 1, 2011 10:40 AM
