Led Lights
Old Apr 19, 2009 | 9:36 PM
MDTAHOE's Avatar
Professional Mechanic
Default Led Lights
I recently replace the tag light bulbs in my 2007 Tahoe with led bulbs. They are a bright pure white color/ Does anyone know of a bulb for the reverse lights that is pure white rather than the yellowish color they are now, to match the tags. From looking online the back up lights are 7441 and I have not been able to find a led in that number
Old Apr 19, 2009 | 9:43 PM
have you checked http://www.superbrightleds.com/
Old Apr 19, 2009 | 9:46 PM
MDTAHOE's Avatar
Yes I have looked there, they do not have them.
Old Apr 20, 2009 | 9:17 AM
I haven't pulled the bulb to look at it but what could be so special about it, its a reverse lamp not a turn signal or multi-element, I wonder if its because of its brightness... I bet you could put a replacement LED in but will it be as bright....
Old Apr 20, 2009 | 8:29 PM
RedondoRon's Avatar
Here's some LED light info from the Cadillac form that maybe helpful.
http://www.cadillacforums.com/forums...alade-led.html
Old Apr 20, 2009 | 8:39 PM
Mike Sigmond's Avatar
ROTM Coordinator
I saw this ad on the top of the page, go figure. You have probably seen already I take it.
http://car-led-bulb.methinks.info/
Methlinks? thats weird.
Old Apr 20, 2009 | 8:40 PM
good find, I bet this will work for the reverse lamps
http://superbrightleds.com/specs/744x-xHP3.htm
Old Apr 20, 2009 | 9:33 PM
MDTAHOE's Avatar
None of those say they will work for a 7441 bulb
Old Apr 20, 2009 | 9:42 PM
Google 7440 images and nothing but lamps and bulbs come up , Google 7441 and nothing remotely resembling a lamp or bulb comes up...
wonder what is up with this unique bulb....
Old Nov 10, 2009 | 7:00 PM
edmc1's Avatar
I've been told you can use a 7440 instead of a 7441 bulb...
