A little noise in my rear?
Old Feb 4, 2012 | 11:16 AM
Utahoe's Avatar
Question A little noise in my rear?
Hi all.
I have a 2001 Tahoe 5.3 Autoride with 160k, I have recently noticed an intermittent noise coming from the rear of the vehicle, sounds like a buzzing or vibration. I have ruled out brakes and Autoride compressor.
Any ideas? Let me know your thoughts.
Thanks,
After doing a little more investigation I believe I may be hearing clutch chatter from from the eaton locking Rear diff. I will try a flush and re-fill and see if that fixes it, if not, does anybody have experience changing the clutch plates, if so, what should I be prepared for?
Thanks again
Old Feb 4, 2012 | 4:32 PM
Welcome to the forum.
Since the Eaton is a locking differential, I doubt that it's the noise source. Have you thought about the fuel pump?
Old Feb 4, 2012 | 4:46 PM
Utahoe's Avatar
Hmmm.. I had'nt thought about that, would it be an intermittent noise. The noise sounds almost like a heat shield or something that when the harmonics are just right will create the sound.
Old Feb 4, 2012 | 5:17 PM
Does yours have a heat shield between the spare and the tailpipe?
bbolin00
Mar 18, 2010 9:18 PM
ace6969
Oct 7, 2006 3:28 AM
cyclist_06
Sep 12, 2006 9:47 PM
