Last edit by: IB Advertising
Browse all: Engine and Powertrian
- Chevrolet Silverado 1999-2006 GMT800 How to Replace Knock Sensors
Location of the Knock sensor 2 Bank 2 on 2007 Suburban
The other day I have noticed that my truck is not idling correcty. After scanning I got the code P0330.
Can someon please point me to the location of the knock sensor 2 bank 2? I've tried searching this forum / Google but was unable to find any diagrams.
I have 2007 Suburban 2500 HD.
Thanks for any pointers.
Under the intake is where I have seen them also but when I looked up 2007 Suburban 4wd for Engine Controls and Fuel - 4.8L, 5.3L, 6.0L and 6.2L
it showed them on each side of the engine !?!
Sorry the pictures don't cut and paste
Service Information
2007 Chevrolet Chevy Suburban - 4WD | Avalanche, Escalade, Suburban, Tahoe, Yukon (VIN C/K) Service Manual | Document ID: 1708249
Knock Sensor 1 Replacement
Removal Procedure
Lift and support the vehicle. Refer to Lifting and Jacking the Vehicle.
Disconnect the engine wiring harness electrical connector (4) from knock sensor.
Remove the knock sensor bolt (739) and knock sensor (718).
Installation Procedure
Notice: Refer to Fastener Notice in the Preface section.
Position the knock sensor (718) to the engine block and install the knock sensor bolt (739).
Tighten
Tighten the bolt to 25 N·m (18 lb ft).
Connect the engine wiring harness electrical connector (4) to knock sensor.
© 2012 General Motors Corporation. All rights reserved.
Service Information
Removal Procedure
Tighten
Now I'm confused; are they under the intake manifold, or are they below the exhaust manifold on either side? It appears that maybe the 2006 and earlier are under the manifold, while the 2007 and later are on the sides?
TylerWalker
12
Aug 14, 2022 12:22 PM
ldearman
May 5, 2011 4:08 PM
