Long cold cranking
Old Jul 25, 2011 | 11:21 AM
cnickels87's Avatar
Default Long cold cranking
Vehicle is a 2002 Chevy suburban, about 140K miles on it. I am having problems with long cranking times especially after its been parked for an hour on longer. I've already changed the fuel pressure regulator, and still have the same problem. I'm starting to lean towards a fuel pump problem. Anyone have any ideas?
Old Jul 25, 2011 | 11:39 AM
EinST's Avatar
Welcome to the forum. It's probably best to check the fuel pressure before embarking on a major job like that. The fuel pressure should be 55-62 psi with key on, engine off. If it started low and only gradually built up, perhaps the fuel filter could be clogged or fuel pump could be on its last leg.
Old Jul 25, 2011 | 12:15 PM
cnickels87's Avatar
Alright I should rent a fuel pressure tester then. Its runs and drives fine just long cranks after it sits for a bit.
Old Jul 25, 2011 | 12:20 PM
AZSCTACO's Avatar
Probably the fuel pump....
Old Jul 25, 2011 | 4:34 PM
kevinkpk's Avatar
Might be. I'd suggest turning the key on without cranking it for 15-20 seconds. Then try starting it
Old Jul 25, 2011 | 8:45 PM
RacerX's Avatar
fuel pump.
Old Jul 26, 2011 | 6:48 PM
cnickels87: Welcome to the forum.
Fuel pressure gauge runs about $30-$40.
Old Jul 26, 2011 | 7:46 PM
RoTo's Avatar
Yep, get a fuel pressure gauge before start replacing unbroken parts.
Geoffrey Dell
Jul 13, 2011 1:00 PM
silver911rdb
Nov 26, 2009 8:06 PM
country_09
Oct 16, 2009 5:41 PM
Typerod
Mar 16, 2008 4:43 PM
a2rivgy
Jun 9, 2007 1:59 PM
