Longevity & Maintenance
Old Dec 13, 2009 | 9:13 PM
Jayybird's Avatar
Default Longevity & Maintenance
Hi,
I just purchased a 2008 Tahoe, 5.3 LTZ with 9k miles on it. This is absolutely the nicest vehicle I have ever owned. I have a couple general questions.
1. What is the oil capacity for this engine? The book calls for 6.0 litres but this slightly goes over the full line on the dipstick. Or is not 6 literes and i am just interpreting the book incorrectly??
2. Is anyone using castrol syntec on this engine, if so, at how many miles do you change your oil?
3. I am open to hearing any tips on prolonging the life of this vehicle, does anyone have any recommendations on how to increase the longevity of this car?
Thanks
Old Dec 14, 2009 | 7:32 AM
pacman13's Avatar
1. I i change the oil myself and i take about 5 and 3/4 qt. and you are right if i fill the whole 6 qt it over the checker area. i quess because some oil get left over when i drain.
2. I used Mobil 1 full synthetic ($22 per 5 qts at walmart) and i switched over since 36K but because i bought it used at 34K. so in term of when is safe or not safe to switch maybe someone else can tell you, sorry!!!
Old Dec 14, 2009 | 7:39 AM
pacman13's Avatar
and i change the oil every 5K or 5 months... but that's my preference, there are others who do it at 7K or 6 months and some even more.
3. My tips on longevity is change the oil regularly, follow the maintenant schedule in your manual.... alots of those you can do it yourself, search this forums there are lots of good informations available here.
Old Dec 14, 2009 | 8:51 PM
MDTAHOE's Avatar
Professional Mechanic
TIME OR MILEAGE
PREVENTIVE MAINTENANCE RECOMMENDATIONS
These are generic service recommendations based solely on time or mileage not on visual appearance or measurement. Their purpose is to extend the life of your vehicle and help prevent breakdown through a schedule of highly beneficial preventive maintenance procedures.
OIL - LUBE – FILTER ---------------------- 3,000 to 5,000 miles*
TIRE ROTATION ----------------------------- 5,000 to 7,500 Miles depending on tire style*
PCV VALVE ----------------------------------- Yearly, replace and service PCV system
WHOLE CAR DIAGNOSIS ------------------ Yearly and before purchase or sale
FUEL FILTER --------------------------------- Yearly or as needed
BATTERY SERVICE ------------------------- Yearly or as needed
AIR CONDITIONING ------------------------ Check every spring or as needed
RADIATOR COOLANT ---------------------- Every two years, flush*
BRAKE SYSTEM FLUSH ------------------- Every year
CLUTCH SYSTEM FLUSH ----------------- Every year
RADIATOR CAP ------------------------------ Replace every two years,
ENGINE OIL FLUSH ------------------------ 2 Years or 30,000 Miles
AUTOMATIC TRANS FLUSH ------------- 2 Years or 24,000 miles*
POWER STEERING FLUSH -------------- 2 Years or 24,000 miles
EGR SYSTEM SERVICE -------------------- 2 Years or 24,000 miles*
4X4 TRANSFER CASE ----------------------- 15,000 to 50,000 miles*
CARBON CLEANING ------------------------ 2 Years or 30,000 miles or as needed*
THROTTLE-BODY SERVICE -------------- 2 Years or 30,000 miles or as needed*
RADIATOR & HEATER HOSES ----------- 4 Years or 60,000 miles
DRIVE BELTS --------------------------------- 4 Years or 60,000 miles
TIMING BELT --------------------------------- 4 Years or 60,000 miles*
DIFFERENTIAL FLUID -------------------- 15,000 to 50,000 miles*
MANUAL TRANS SERVICE ---------------- 15,000 to 50,000 miles*
VALVES ----------------------------------------- Adjust per owner’s manual
SCAN FOR COMPUTER CODES --------- When amber “CHECK ENGINE” Light is on
OXYGEN SENSOR --------------------------- Per owner’s manual or as needed
*YOUR VEHICLE’S REQUIREMENTS MAY DIFFER DEPENDING ON DRIVING HABITS AND/OR OWNER’S MANUAL RECOMMENDATIONS. CHECK YOUR OWNER’S MANUAL AND WITH YOUR SERVICE ADVISOR FOR SPECIFICS.
Old Dec 14, 2009 | 8:56 PM
nauticstar87's Avatar
I suggest sticky that.
damone
Mar 1, 2015 11:33 AM
brock6051
Mar 17, 2014 10:23 AM
OTHARANI11
Oct 14, 2011 11:44 PM
fordeater
Apr 26, 2010 2:52 PM
