Low Idle??
We have a 2003 Suburban that stalls whenever we come to a stop, like at a stop sign or traffic light, in order for it not to stall we have to step on the brake while maintaining the other food on the gas to keep the idle a little high. This doesn't happen if the car is on P. This is why hubby thinks it is he idle. Has anyone had this problem? How was it fixed?
Thank you so much for your time.
I wanted to thank you for your IAC advice. Hubby did just that and he said it was so dirty it was horrible. Once he cleaned it... What a difference!!!! WOW!!! The truck runs so nice and smooth now.
Thank you thank you thank you!!!!!!
hey had the same problem. but it wouldnt stall.. once it did but just kinda slowly clugged as if it wanted to die. awesome when driving. so.popped the hood and adjusted the idle cable to "automatically do the brake foot peddle".. is that bad?
Not so much bad, but it is going to be wasteful for fuel and a band aide for the real problem...
I would suggest cleaning the throttle body and plate as well as the IAC, and remove any mod you did to the cable... if you after that you still have an idle problem more troubleshooting is needed...
Welcome to the forum...
:chug:
the68
Jul 21, 2013 1:09 PM
vanmanpdx
Jul 9, 2012 2:04 PM
JK
