low tire light stays on even though tire pressure is good
Old Jul 5, 2018 | 7:20 PM
Ken3000's Avatar
Newly Registered
Default low tire light stays on even though tire pressure is good
2008 Chevy Suburban 1500 low tire light stays on constantly. I can read every tire pressure from the display and all are good. I have rotated tires and have reprogrammed the tpms to the new locations but light stays on
Old Jul 6, 2018 | 1:58 AM
oilcanhenry's Avatar
I wont even replace mine when I need new tires. I have no need for a tire air-pressure warning system. I'll put a piece of tape over the light and keep driving.
Old Jul 6, 2018 | 7:54 AM
Warren_CERT4's Avatar
It can be 2 things: 1) the Placard Pressure was changed or 2) the Key module needs to be re-flashed. Do you have access to a scan tool to pull any possible DTC's and/or pull the current Placard Pressure the vehicle thinks it needs to be set to?
Old Sep 5, 2018 | 1:24 PM
KcH918's Avatar
One of your tire pressure sensors is bad and needs to be replaced, but it's not a must in order to drive the truck or what not. Only if you find the light on the dash annoying. I however have gotten use to mine bc I'm cheap lol.
Old Sep 8, 2022 | 4:13 PM
rcorn1031's Avatar
Banned
Default your reply is useless
How can it be a bad sensor when reported t.p. is “IN SPEC” And Tire pos. relearn was successful ?
You have No Clue .
Old Sep 10, 2022 | 10:53 AM
buttanic's Avatar
The battery in the sensor is dead, they don't last forever and can't be replaced and a 2008 is 12 years old. Mine went dead at about 8 years so you done good. By new ones and replace then all when you replace tires.
https://www.rockauto.com/en/catalog/...)+sensor,12036
Old Sep 10, 2022 | 11:18 PM
rcorn1031's Avatar
Banned
Default Wrong assumption
Sensors are only THREE years old and all were replaced at the same time then .
Old Sep 11, 2022 | 5:51 PM
buttanic's Avatar
Go to Auto Zone and have them do a scan for any codes and reset if any are found. They don't charge to do it.
Old Sep 11, 2022 | 7:04 PM
rcorn1031's Avatar
Banned
I discussed this at length with another mechanic and we somewhat agree that apparently when I replaced ALL the sensors 3 years ago apparently those had sat upon a shelf somewhere for some time and one sensor has a weak battery .
I’ll just reorder and replace them all again . I’ll also ask the Manufacturer of my Diagnostic tool why there is no coverage for ‘07-‘13 Silverados or GMC Sierras .
Thanks for the reply
sue111
Nov 5, 2018 5:08 PM
Lindsay 84
Sep 28, 2013 7:11 PM
OTTO
Jan 17, 2008 3:29 PM
mijonq
Nov 28, 2007 6:52 AM
little
Apr 16, 2007 3:44 PM
