mixing oil and water
Old Jun 20, 2009 | 1:53 PM
damtahoe's Avatar
Default mixing oil and water
i have 96 tahoe with vortec heads just rebuilt 2000 miles just started mixing.runs great no missing or codes .heads were done in florida they were reworked to 062 cast specs. i noticed they were cracked and had been pluged to repair.shoud i be looking at head or intake leak? getting mixed answers. please help
Old Jun 22, 2009 | 8:12 PM
Welcome to the Chevrolet Forum. Any coolant in the oil?
Old Jun 23, 2009 | 4:17 PM
damtahoe's Avatar
yes there is water in motor but no oil in radiator
Old Jun 23, 2009 | 9:16 PM
Sounds like they didn't do a good repair on your cracked heads. If it's leaked coolant into the oil for 2K mi, then probably have to do another rebuild as the bearings are going to let go.
Old Jun 24, 2009 | 11:15 AM
damtahoe's Avatar
tahoe started mixing in the last 2 miles.I got up checked oil drove 2 miles to parts house for a light bulb seen a spot under truck (front seal leak due to bad timing cover)that is when i checked oil again and seen the mix.Ihave not started since then.Timing cover molded wrong front seal not centered so it leaks small amount.
PastorK
Sep 18, 2021 10:20 AM
usernamehere
Aug 2, 2021 12:07 PM
grndslm
Dec 18, 2012 2:38 AM
jody78
Oct 4, 2010 8:16 AM
SuperTexan
Nov 21, 2008 3:57 PM
