Moan/Groan from the rear!!! Differential?
Old Dec 13, 2010 | 7:24 PM
jvtahoe's Avatar
Default Moan/Groan from the rear!!! Differential?
I get this moan/groan from the rear when backing up or driving off. This is more prevalent during the morning at first drive off. I also notice it after the car has been at rest for a while.
Does anyone else have this same problem on '07 Tahoe? What is it and how do you fix it?
Old Dec 14, 2010 | 8:44 AM
mturnerua's Avatar
I had a similar issue with my 07 too. I noticed a moaning type sound mainly when driving around 50 mph and coasting. I took it to the dealer and they replaced the pinion seals and that solved my problem. Now mine had about 98k on it but was still covered under the 100k warranty.
Old Dec 15, 2010 | 6:49 PM
jvtahoe's Avatar
Mine only last for a few feet of driving then it goes away.
Old Dec 16, 2010 | 11:27 AM
DoubleO7's Avatar
Disc brakes on the rear axle?
If yes, could it be caused by the overnight rust on the rotors being wiped off after a few rotations?
Those pinion seals must have pretty stiff to make groans and moans!!!
Maybe they replaced the pinion bearings too?
If those went bad it would moan and groan.
Old Dec 17, 2010 | 10:19 PM
RacerX's Avatar
yea, it sounds like disk brakes pad on the rear rotors. give this a try, hold the pedal lightly as you shift into gear and see if it makes that groan, forward & reverse.
rjdjbd
May 2, 2014 5:50 PM
den458
Astro
15
Jan 12, 2014 11:28 PM
monteash
Oct 2, 2007 11:19 PM
sm3earl
10
Feb 14, 2007 12:31 AM
jordanhaskins
Nov 7, 2006 2:33 AM
