tire pressure monitor
Old Dec 16, 2010 | 2:41 PM
ebellanca75's Avatar
Question tire pressure monitor
Hello I wish to remove the transmitting tire valve with regular ones. Can I disconnect the tire pressure monitor to avoid the warning signs in the cluster.
Old Dec 16, 2010 | 8:46 PM
Welcome to the forum.
I don't know but not sure why you'd want to remove them.
Old Dec 18, 2010 | 3:05 AM
QUETRANPA's Avatar
you know I just upgraded to 20" aftermarket wheels, and thanks to a guy at the dealership I didn't install the TPMS in the new wheels, (he said that you just take the TPMS fron the stock wheels and install them in the new ones, but he didn't mention that new valve stems are needed for this install, so the guy at the tire place installed the regular valve stems) so I got the stupid warning light in the cluster!!! what did I do? I just put the sensors in a pvc canister that I just made a couple of hours ago! and I'm going to pump it up to 35 psi place it in the truck and the light will have to go off thinking that I now have good pressure in all 4 tires, lets see what happens.
But why in hell do you want to remove the TPMS from your truck anyway?
Now I don't know if you are going to get a second warning light on the cluster if you unplug the one for the TPMS but I guess that the best thing to do in your case is what I did with the sensors.
racingrusthotrods
Colorado
23
Dec 25, 2013 6:13 PM
bama1
Dec 7, 2008 10:09 PM
FARRNARK
Oct 23, 2008 9:12 AM
fe_pony
Mar 22, 2008 7:33 PM
ambiguous216
Mar 11, 2007 12:25 AM
