My Suburban won't drive in two-wheel drive but drive okay in 4-wheel drive
Old Sep 20, 2018 | 3:57 PM
G20 rider's Avatar
Default My Suburban won't drive in two-wheel drive but drive okay in 4-wheel drive
Okay so I jacked up my 2001 Chevy Suburban off the ground and put it on jack stands I put the car in 2 wheel drive and the drives the rear drive shaft with spin but the tires will not spin so I put the car in neutral then put it in 4-wheel drive then put it back in drive the front wheel spent the rear driveshaft spent but not the rear tires any idea on what it could be please help
Old Sep 20, 2018 | 4:52 PM
geo1's Avatar
Took out the rear differential?any noise before?
Old Sep 20, 2018 | 7:25 PM
pull the diff cover and inspect
Old Sep 20, 2018 | 11:27 PM
G20 rider's Avatar
@ geo 1 it was doing popping sounds when i turned
Old Sep 20, 2018 | 11:29 PM
G20 rider's Avatar
Originally Posted by tech2
+1
@tech2 what should I'm looking for
Old Sep 21, 2018 | 8:01 AM
Tdub's Avatar
You shouldn't have to 'look' for anything. Popping when turning, driveshaft spins but wheels don't. My only advice is try not to let any of the gear/bearing carnage hit you while removing the cover.
If a differential rebuild is not something you are willing to do yourself, save yourself the time and mess for the person/place who will be doing it.
Old Sep 21, 2018 | 1:43 PM
falconbrother's Avatar
If the rear drive shaft is spinning but the axles aren't you have a bad differential. The 9th gen differentials were an issue. Mine was rebuilt about two years ago. It's not real cheap to get it done so, shop around. But, it's worth it. It's not a job that a novice can do. It takes an experience mechanic and special tools to overhaul a diff.
Old Sep 21, 2018 | 2:00 PM
G20 rider's Avatar
yeah that's what I was planning to send it to a shop and let them do it and I'll just wanted to be sure that's what it was before I sent it because I didn't had other guys tell me that it was a whole lot of different other stuff that had nothing to do with my rear end it was all front end like ball joints and tie rods and talk about that's what was popping when I was turning and it turns out that wasn't the case my rear axle was going out all the differential case whatever you want to call it I just wanted to troubleshoot for myself but thanks for the advice and information it was truly valuable thanks to all the guys deceptive dick head up above talking about gears hitting people in the face but everybody else I appreciate your input and help
