My Windshield Wiper Vent
Old Apr 26, 2007 | 1:57 PM
Hatchfinder's Avatar
Default My Windshield Wiper Vent
These wipers suck. They, suck, they suck, they suck, they suck! There's no getting around it, they suck and Chevy needs to either get them figured out or just keep warranting them every 3 months forever. Before I vent you should know my Tahoe is only a few months old, it's not like I've had these wipers on for a year or two.
Last week I drove through a 4-hour snowstorm before coming to a town big enough to support a Chevy dealer. Here's my vent:
The problem with the passenger side wiper is that in the down position it hangs off the windshield by approximately 2 inches. This overhang collects ice so when the wiper wipes, the ice that's been collecting doesn't allow the wiper to touch the windshield. And it just keeps getting worse as more and more ice collects.
The driver side wiper isn't much better. It leaves a perfect3-4 inch streak right in the field of vision. This streak then turns into ice and...............pisses me off because I can't see the damn road without leaning to one side or sliding down in my seat. Also, the wiper is so long that when it reaches the up position it touches the windshield/roof connection and makes a really obnoxious "click" noise. Now that's fine for quick, around town stuff but try listening to that for 4+ hours.
So finally I find a Chevy dealer, because buying normal wipers at an auto supply would just be too easy, and I walk in with my wipers in handto let he parts guy know I need wipers for an 07 Tahoe. He walks back and grabs a normal set of wipers. I'm like, ummmm, these won't work. The parts guy had no idea Chevy makes "special" wipers now. Where's the smiley banging his head against the wall? So he jumps on his computer and locates the closest pair, they are 4 hours in the direction I just came from.
Chevy, this is 100% unacceptable and 100% unsafe. Where's the fix? The recall? Where’s the normal wiper upgrade? Where's the Winter blades?
Old Apr 26, 2007 | 2:07 PM
jazejeff's Avatar
Default RE: My Windshield Wiper Vent
WOW!!!! i would hate to see you have a problem with the rear one too!!! lol
snow ? ice ? what is that!! i guess living in california i forget what a pain it would be to have that problem
hopefuly they will fix the problem!
Old Apr 26, 2007 | 2:53 PM
davemec
Guest
Posts: n/a
Not sure if this is correct, but Advanced Auto shows these replacements as being a direct fit for the 07 tahoe:
http://www.partsamerica.com/productd...33&PTSet=A
Old Apr 26, 2007 | 3:47 PM
biglg's Avatar
I drove once in the snow/ice and I to wasnt impressed. However, I dont expect much when it is freezing rain outside. I dont seem to have the rubbing and noises you have!
Old Apr 26, 2007 | 4:29 PM
ibcheeky's Avatar
Looks like Trico makes a complete wiper assembly for the 07 model as well.
http://www.macautoparts.net/ProductInfo.aspx?id=2819069
Old Apr 26, 2007 | 8:07 PM
RonH's Avatar
ORIGINAL: ibcheeky
I see they havewipers in 10" length. If you got some of those, they wouldn't hang out over the edge of the windshield to catch that ice and snow.
Old Apr 28, 2007 | 12:49 AM
ORIGINAL: ibcheeky
Kind of pricey. The Valeos from Chevy retail for $30 but you can get them for about $22 each if you get to know the parts guys. At least maybe this means they'll come out with a winter blade.
Old May 22, 2007 | 2:14 PM
I bought a set of these refills: http://www.partsamerica.com/productdetail.aspx?MfrCode=TRI&MfrPartNumber=4 5210&PartType=333&PTSet=A
While they probably fit (I didn't install them because it's a real PITA to get the end caps off of the blade so you can slide the refill out), they don't have the wind deflector on top which is part of the rubber blade.
Old May 22, 2007 | 10:53 PM
Zed 71's Avatar
I have the heated windshield fluid option. I hope that it works well enough to eleviate the problem.
Old May 22, 2007 | 11:14 PM
It certainly helps. Especiallyif you use the washer fluid that has the deicer in it.
sm3earl
Feb 17, 2008 8:20 PM
sm3earl
Jan 30, 2008 4:36 PM
lightGear
Feb 20, 2007 7:45 PM
mudman
Jan 13, 2007 7:04 PM
