Nav/radio does not turn on
Old Apr 15, 2007 | 7:31 AM
lvegaskid1's Avatar
Default Nav/radio does not turn on
2007 Tahoe
I tried to install the lockpick today and when I was done with the installation the screen would not come on. (it was working prior)
I unplugged the lockpick and put everything back in its original position but the nav/radioscreen still does not come on.
Is there a reset button, I've tried everything... PLEASE HELP
Old Apr 15, 2007 | 11:04 AM
07summitwhite's Avatar
Default RE: Nav/radio does not turn on
Have you tested the fuse for the radio? I would start there. If so, let the dealer figure it out. Just play dumb.
Old Apr 15, 2007 | 11:11 AM
ZX1100F1's Avatar
ORIGINAL: 07summitwhite
Just play dumb.
I have a 13 year old I can lend you for this. I tell you; a true proffesional when it comes to "playing dumb".
When I installed the new Gen-3 Lockpick last week my nav radio also would not turn on however, when I put everything back the way it was (with the Gen-1 Lockpick) it worked properly again.
Old Apr 16, 2007 | 6:24 AM
lvegaskid1's Avatar
07summitwhite: How do I test the fuse and where is it located.
I am going to unplug the battery overnite to see if that works!?
If not, I am playing dumb like dumb n dumber... Guess I'll have to put the stereo cover back on, that was such a B*%$# to get off!
Old Apr 17, 2007 | 12:44 AM
lvegaskid1's Avatar
CAn anyone tell me where the fuse is???
Old Apr 17, 2007 | 1:21 PM
konasmrz's Avatar
ORIGINAL: lvegaskid1
Owners manual should tell you the location.
Otherwise,one suggestion- make sure you fully inserted the plugs back into the radio; they snap in almost flush (the small blue lock tabs should be in the "unlocked" (pulled out) position before you try to reinsert)
Old Apr 17, 2007 | 6:58 PM
gm_geek's Avatar
Fuse box located inside of Your engine compartment on the right (driver) side
when you pull fuse box cover out, you'll see a sticker look like picture below.
BTW I high_lighted Radio Fuse for You
Old Apr 17, 2007 | 7:49 PM
lvegaskid1's Avatar
AWESOME! Thanks guys, Ireplaced fuse41 with another one, re-did the install and everything is working great now. I love the gen-3 lockpick.
Old Apr 26, 2007 | 2:56 PM
JUNIOR's Avatar
whats the diffrence in the gen1 and gen 3 lock pic ??? i asume i have the gen1 when did the gen3 come out
Old Apr 26, 2007 | 2:57 PM
JUNIOR's Avatar
actually found reciept and i purchased mine in nov 01 2006 what do i have gen1 ??
goyakpacking
May 9, 2015 7:51 PM
shant
Feb 23, 2011 9:08 PM
ridgemeadows
Jan 24, 2010 3:27 PM
antics22
Aug 22, 2006 12:07 PM
