Navigation Install Question
Old Jul 23, 2009 | 8:39 PM
95z115's Avatar
Default Navigation Install Question
On a 2007 Denali with a OEM GM CD player unit, we took out the CD player unit and installed a OEM GM navigation unit, part#25797978. After the install, everything works fine (nav,radio,cd), with the exception of the volume. The volume is pretty loud and will not respond to the steering wheel volume control or the volume **** on the nav unit.
The steering wheel volume worked fine before, so I know there is nothing wrong with the steering wheel. Could it be a locked volume setting on the nav unit or even a loose connection?
What could be the problem?
Thanks in advance for your help...
Old Jul 24, 2009 | 8:32 AM
95z115's Avatar
help!
Old Jul 24, 2009 | 9:44 AM
SabrToothSqrl's Avatar
Default nav
from what i've read you have to go to the dealer for them to setup something after you install it...
Mine came factory, so I'm not sure... sat nav was on the must have list...
Old Jul 24, 2009 | 6:08 PM
shawnvw's Avatar
Banned
I'll assume you followed the guidelines of installing a NAV, https://chevroletforum.com/forum/tahoe-suburban-25/how-install-oem-nav-2007-tahoe-2155/
Your problem is a programming issue. Have the dealer program the radio, paying close attention to the RPO codes on the SPID label in the glove compartment
Old Jul 25, 2009 | 2:32 AM
95z115's Avatar
Thanks for the info guys, shawnvw, I will apply those instructions and make sure the install is done correctly. Hopefully it solves the problem...
Thanks again!
JDahl
Jun 1, 2008 11:18 AM
StormPursuit
Sep 18, 2007 8:43 AM
ramo
Aug 21, 2007 11:01 AM
Chipitolay
Jul 7, 2007 4:55 PM
pat130
Jun 11, 2007 5:00 PM
