Is the navigation voice-enabled?
Old Oct 4, 2008 | 8:04 PM
thetahoe's Avatar
Default Is the navigation voice-enabled?
I have an 08 Tahoe LT3 with the factory navigation, and from a few things I've read around, it seems to also use your voice to take commands. If so, how in the world do you do this? I can't seem to figure it out.
Old Oct 4, 2008 | 10:07 PM
Default RE: Is the navigation voice-enabled?
If you got it new, there should be a Nav Manual in the portfolio. If not, register at mygm.comand you can download. If you got it new and didn't get one, get the dealer to give you one.
Old Oct 5, 2008 | 10:04 AM
thetahoe's Avatar
Yeah we got it new and I remember the Nav manual but I guess I misplaced it. I'll be looking for it, I think it's in the glove box.
Old Oct 5, 2008 | 10:31 AM
rruelas's Avatar
If you press and holdthe mute button on the steering wheel for about three seconds, the unit will beep and the mute symbol on the nav screen turns into a man speaking. say "help", and the nav unit will give you a little tutorial about the Voice comands. You can change the radio station, access onstar, chose if you want to listen to cd and go to a perticular track, xm, navigate to a stored destination, change to day/night mode, all kinds of things. Now this only works if you had your navigation installed at the factory, or if you put in the nav unit yourself, connected the two wires that go from the nav unit to the onstar module.
But after playing with for a little bit, to me, its quicker just to press the buttons on the navigation itself to do what you want to do
Old Oct 5, 2008 | 12:05 PM
thetahoe's Avatar
Thanks! I went to try it and it worked! I wondered why they only put that button there for mute.
New Traverse
Traverse
14
Oct 7, 2009 1:16 AM
SabrToothSqrl
Aug 24, 2009 3:05 PM
SabrToothSqrl
May 21, 2009 10:05 AM
BT
Oct 20, 2007 7:59 AM
jasonw75
Aug 16, 2006 11:01 PM
