Old Jul 22, 2015, 10:16 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
Need advice on new Rotors & Pads
Old Mar 24, 2011 | 7:55 AM
pervitizm's Avatar
Default Need advice on new Rotors & Pads
So I've got an 07 suburban that came stock with disc brakes all around the rotors are 13.6 up front and 13 in the rear. I'm about to finally put my 26's on the truck in about two weeks, however before I do that I want to change out the stock rotors and brake pads. Now I'm not talking about doing a Wilwood or Baer brake kit type of deal cause......I ain't got that kinda money. But what I was looking at doing was going with EBC's slot/drilled rotors up front and maybe just some slots in the back along with their green stuff pads. You guys think that will be a good way to go or just do slot/drill rotors all the way around?
Any other brands that I should be looking at besides EBC that offer good factory replacement Rotors and pads?
3DG Slot Rotors
Green Stuff 6000 Pads
Old Mar 24, 2011 | 11:52 AM
Good thinking on brake upgrade w/ those monster wheels.
I've heard/read rumors of some drilled rotors having cracks that start at the holes. Might be better to get the ones w/ the ball milled grooves.
Old Mar 24, 2011 | 3:33 PM
pervitizm's Avatar
Yeah I heard about the drilled rotors having issues too but these are drilled through rotors. They are what is known as dimpled drilled rotors where the drill holes don't go through the rotor. I may just step it down to regular slot rotors however when I went to the parts store (O'Riely's) they have Wagner rotors for around $400 that have lifetime warranty on them. They are just stock OEM replacement rotors (non performance) but they do come in at almost $200 cheaper than going with the EBC's from the same store. Don't know what I should do though.
Old Mar 24, 2011 | 8:34 PM
If you aren't getting a bigger diameter rotor, then not sure why you'd want to change.
Old Mar 25, 2011 | 6:20 AM
pervitizm's Avatar
Like I had said before I'm going from 17's stock rims to 26's custom rims on the truck next week. The current brakes I have on the truck are not good and I can tell just by stopping that my rotors are warped. I want to get rotors and pad on the truck that are good for the extra mass that I'm going to throw at them without warping the rotors. I'm also looking at Power Slot rotors too. They have a better warranty however they only have slotted rotor on no slotted/dimpled rotors.
Old Mar 25, 2011 | 12:34 PM
08 burb fan's Avatar
I put Power Slot rotors and Hawk pads on my Burb.
Stops 1000% better with no chatter.
Old Mar 25, 2011 | 8:52 PM
With those bigger, heavier wheels, you'll need larger rotors to both stop and to keep from overheating and warping the rotors.
Old Mar 26, 2011 | 6:15 PM
8rings's Avatar
If you are looking for increased cooling then slotted rotors will perform better than cross-drilled and they don't have the associated cracking problems. BUT slotted and cross-drilled rotors actually produce longer stopping distances due to the decreased surface area. The reason they "perform" better is that they are better at dissipating heat and therefore don't fade from heat under prolonged braking. Slotted or cross-drilled rotors are usually overkill for a road car as they don't see the constant braking conditions like on a track. If you were coming down a long winding mountain pass they could be beneficial, especially if towing.
Old Mar 27, 2011 | 6:01 AM
I also changed out he brake lines to steel braid.
Old Mar 30, 2011 | 11:47 AM
Mad Dawg's Avatar
If you are going to spend several thousand on new wheels/tires, why cheap out on the most important safety feature on your vehicle?? You really should look at getting a BBK.
