need help!!!!
Old Sep 25, 2018 | 9:00 AM
wa101's Avatar
Default need help!!!!
hi, i'm new here. but I have 2008 chevy suburban. about a week ago, the truck started to drive funny. it wouldn't go pass 35 mph and the reduce engine power pop up. I first check the transmission fluid, it was low. I added what was needed. and then I scan the truck and I got code p0641. so after I ran the scan I started the truck an it stayed running for about 5 min then shut off on its own. I tried to start it again an it wouldn't start. so i kept trying to start it. an it wouldn't start. I listen for the fuel pump to come on, I didn't here nothing. so now I go thru the fuses they were good and then I go an check FSCM. I went off of GM FLASH procedure. an I came up with fscm was bad. so I order one from GM FLASH. and after I installed the new fscm , the truck still not starting. if I hot wire the fuel pump, it do come on. I check the fuel rail an there is gas coming out. I don't know the psi of it. but is there anyone who can help me, I would love to hear from u thanks.
Old Sep 25, 2018 | 9:50 AM
oilcanhenry's Avatar
Well,I dont know much about this GM FLASH, but that could be the issue. P0641 is a problem with your tranny.
Old Sep 25, 2018 | 10:36 AM
Tdub's Avatar
There is a pip bulletin or document #2234180 (add p0641 to narrow your search) referring to a possible short in the wiring harness by the front drive shaft. I know there is a forum somewhere that somebody posted the details. Your Suburban falls under the affected applicable models I believe.
Old Sep 25, 2018 | 12:02 PM
geo1's Avatar
Tdub,that you from the other"ego"site?,glad you're hear,just a great group of contributers here,been a great experience here,no attacks,if a reply is not spot on,a thank you to all!
Old Sep 25, 2018 | 2:51 PM
wa101's Avatar
Default Need help!!!
Thanks for the reply, but do you think that code P0641 is stopping the truck from starting?
Old Sep 25, 2018 | 5:21 PM
geo1's Avatar
Did you Google the 641?many possibilities,it's open 5v reference,so now to figure out what sensors are on the 5 v reference and test them,you said it ran funny,could be cam sensor
Old Sep 25, 2018 | 7:01 PM
wa101's Avatar
How would I figure out, what all sensors use 5 volts? And one thing I forgot to mention is. Sometimes when I'm trying to start the truck, it would start for about 3 sec. an then cut off. It will do that every time it sit for a little while. But if I try to start it right after it cut off. It just crank with no start.
Old Sep 25, 2018 | 7:17 PM
Tdub's Avatar
geo1, you caught me. Glad your here too my friend. Definately seems like a great place here.
@wa101, were you able to see that document? I didnt want to post the text of it since I'm unsure about copyright. If there is damage to the wires in the harness, you could have 1 code, no codes, or 15 codes. 1 symptom, or many. The special keywords in these bulletins are "may" and "and/or". I hope you don't think that I'm insisting that this is your issue, but I do think that document includes your vehicle, symptoms, and your code (p0641). Doesn't cost anything but time to take a closer look.
Old Sep 25, 2018 | 7:24 PM
geo1's Avatar
Yep,Google 2008 GMC Yukon,reduced power mode po641 00 stored. Sparky's answers.com should show up
Old Sep 25, 2018 | 7:34 PM
wa101's Avatar
Default Thanks
Thanks for the info.
