Need help asap
Need help asap
Hi I have a 1997 Tahoe 5.7. Recently my tachometer, speedometer and shifting gauge stopped working, as well I have noticed that my transmission isn't going into first gear in drive unless I manually put it in 1st.
I have taken into a trust mechanic, and he stated that it is my ball body, the solenoids. Now I know that can be an issue, if the transmission is the only issue. I have gone through a few other forums and read that it can be my ignition switch.
I had the codes checked out, P0740, P0753, P0758,P1860, and P0785 were being shown. I also checked the fuse box and noticed that #20 didn't have any current flow but wasn't blown. I have replaced it.
I also have already looked at the wiring to the ignition switch and all are showing current flow except for the purple wire in the middle. I need to know if this can still be the issue or should I be looking at something else. Or is there another way to check the power to the ignition switch.
Please Help!
Thank you in advance
Please Help!
