Need help asap
Old Aug 11, 2014 | 9:18 PM
big daddy cow's Avatar
Default Need help asap
Hi I have a 1997 Tahoe 5.7. Recently my tachometer, speedometer and shifting gauge stopped working, as well I have noticed that my transmission isn't going into first gear in drive unless I manually put it in 1st.
I have taken into a trust mechanic, and he stated that it is my ball body, the solenoids. Now I know that can be an issue, if the transmission is the only issue. I have gone through a few other forums and read that it can be my ignition switch.
I had the codes checked out, P0740, P0753, P0758,P1860, and P0785 were being shown. I also checked the fuse box and noticed that #20 didn't have any current flow but wasn't blown. I have replaced it.
I also have already looked at the wiring to the ignition switch and all are showing current flow except for the purple wire in the middle. I need to know if this can still be the issue or should I be looking at something else. Or is there another way to check the power to the ignition switch.
Please Help!
Thank you in advance
Old Aug 11, 2014 | 9:30 PM
Welcome to the forum...
Looks like you are on the right track about the purple wire..
see attached PDF
File Type: pdf
Old Aug 11, 2014 | 9:45 PM
thank you
do you think it sounds like the ignition switch after all.
i don't know what else to look at.
Old Aug 11, 2014 | 9:51 PM
I'd at least check fuse #8 in the IP fuse block that it indicates in the diagram...
Old Aug 11, 2014 | 10:13 PM
ok.
After I check fuse #8 and what does it mean if it happens to be like #20 and #14. where its not blown but no current. what should i be looking at
sdfd504
Dec 23, 2019 7:19 PM
07impalals
Nov 14, 2007 5:51 PM
neelay
Oct 11, 2006 3:31 PM
artistx
Mar 24, 2006 8:27 PM
