need help with brake issues
ok so I have 2000 suburban 1500.i pull the rear tire to change pads.and the pad that set on the caplier is messed up bad.but pad on the outside look good.what could have caused this issues?it dual piston caplier are they worth rebuilding?
As far as I know regular use of the parking brake keeps the rears adjusted, and you'd be surprised at just how small the parking sprag is that holds the vehicle in place.
jonrowe81
Sonic (Aveo)
January 8th, 2015 4:21 PM
