need help with brake issues
Old Jul 21, 2013 | 2:55 PM
2000suburbanjeff's Avatar
Default need help with brake issues
ok so I have 2000 suburban 1500.i pull the rear tire to change pads.and the pad that set on the caplier is messed up bad.but pad on the outside look good.what could have caused this issues?it dual piston caplier are they worth rebuilding?
Old Jul 21, 2013 | 4:03 PM
Sounds like the caliper stuck. Be sure that the pins are clean and lube them w/ caliper grease that usually comes w/ new pads.
Old Jul 21, 2013 | 4:10 PM
I would concur, make sure the caliper is able to freely move....
Do you regularly use your parking brake?
Old Jul 21, 2013 | 6:23 PM
I will check that along with the boots seals.no I don't use the parking brake much.
Old Jul 23, 2013 | 2:07 PM
As far as I know regular use of the parking brake keeps the rears adjusted, and you'd be surprised at just how small the parking sprag is that holds the vehicle in place.
mikeythe613
Jul 17, 2010 7:51 AM
Mike767
Jun 15, 2009 9:59 PM
01yeehaw94
Mar 29, 2008 8:41 PM
CRFrizzell
Jun 28, 2006 7:47 PM
