NEED MAGNAFLOW WITH NO DRONE
Old Feb 15, 2008 | 2:24 PM
Aquarius14's Avatar
Default NEED MAGNAFLOW WITH NO DRONE
I'm looking for a MF exhaust that has a nice sound withlittle to no droneinside.I've been reading post on this for the last 2 days and still don't have any clear part #'s that I can use to order from Performance Peddlers. I plan on just replacing the stock exhaust & removing the resonater & adding atip.If anyone has this setup please respond.
Old Feb 15, 2008 | 2:59 PM
jophilpott's Avatar
Default RE: NEED MAGNAFLOW WITH NO DRONE
I had mine done at a shop in town. Custom built. They used the MF muffler, but built the rest from 3" stainless. I couldn't tell you the part numbers because I didn't pay that much attention. I don't notice the sound in the cab much at all. But what you would consider little to no drone and what I would consider little to no drone are probably not the same. And if you have an 07/08 I think the whole kit part number is 16672.
Old Feb 15, 2008 | 3:24 PM
AZSCTACO's Avatar
Here ya go...
Part #14579 5x11x22
http://www.hottexhaust.com/detail.asp?PRODUCT_ID=14579
or this if you don't need the stainless...
http://www.hottexhaust.com/detail.as...CT_ID=12579%20
Old Feb 15, 2008 | 7:29 PM
Aquarius14's Avatar
I must be on the right track because I came up with 12589 instead of 12579. Only difference is 1 is offset on the inlet side. So the million dollar ? is which 1? Center/center or offset/center? Thanks Azsctaco
Old Feb 16, 2008 | 2:53 AM
e's Avatar
e
you say the stock exhaust, but you really mean muffler correct? You will get a little drone inside but its not bad. When you go from 8 to 4 cylinder is where your really going to hear the difference. At first it seems a little loud but of course as time goes by it will mellow down a little. I really dont mind the tone and I dont feel that it has a drone inside. I am however running the full catback on ours. I settled for the magnaflow, but really wanted the Corsa with the RSC technology. ThisCorsa is super quite until you hit the gas. The only reason I didnt get the Corsa was because of the rear exit instead of the side exit. The did have plans of making the side exit but I just tired of waiting........
Old Feb 17, 2008 | 2:09 PM
scott_mckinney's Avatar
Available here: http://020289f.netsolstores.com/magn...ustsystem.aspx
Old Feb 18, 2008 | 9:26 AM
Big D's Avatar
Aquarious
12589 is the correct one... Center inlet and offset outlet...3" diameter....Don't waste money on catback system. Also 12589 is stainless steel but not polished (unless you are going to show the exhaust there is no need for polished SS - except you have to get a nice exhaust tip). The Tahoe exhaust pipes are already stainless steel with a 2.8" diameter - so the 3" will work fine (preferably welded by a muffler shop). I bought one about 1 year ago.... SUPERB no complaints whatsoever. I also removed the resonator and had an oval Magnaflow exhaust tip...Total price about $200. vs a $600 cat back system.... Also, to be honest, don't expect any mileage or performance gains.... strictly a sound effect device....The system comesalive around 50 MPH, but no drone, just right sound to let you know you have a 300+ horses under the hood.
Big D
Old May 13, 2008 | 10:19 PM
mike@thepowdercoater's Avatar
Old May 14, 2008 | 6:34 AM
I have been in the hospital and not able to send payment out due to medical conditions. I have sent the powdercoater several emails explaining my situation... I think that is very wrong to simply make a username to post something irrelevant to the thread, when I have been an active participating member on here for almost two years... Once I am no longer on medical leave and I am able to send payment, I will, that is reasonable with my medical conditions...
ratherplaythanwork
Jul 18, 2011 8:50 PM
rayfry
Feb 27, 2011 12:00 PM
jsm
Mar 10, 2008 7:06 PM
71cuda
Feb 18, 2007 11:46 PM
